Shift Carrier Question
  • SirMaxximus
    • Oct 2014
    • 180
    #61
    Looked at this thread earlier this week! Was hoping to shed some light on it because it doesn't have much of an answer... I was switching from a G250 to a ZF
    I had at my disposal an entire shifter assembly from a 328 (ZF) and a 325 (g250). Was able to mix and match and was hoping to let any future readers know what for sure works... the honest and unfortunate answer is nothing works perfectly, there isn't a clear answer, at least for me there wasn't. Here's how the ZF carrier lined up for me:
    Getrag 250 carrier:
    The ZF is more slightly more centered, but too far forward and to the passengers side
    The Getrag is about perfect front to back, but is pretty far to the passengers side.
    Either seems like it would work fine, you'd have the classic "rubbing into 5th"... I ended up heating up the getrag carrier with a torch and bending it to the left. This turned out incredibly easy and worked great! got it to sit perfect... But lining up the shifter with the rod is another story, it would sit too far forward or too far backwards... again, all of them work work. but i found rubbing into certain gears... the 328 shift rod was the only one that was close. I ended up twisting and welding one of my shifters to get it to fit perfect... I know thats not helpful for anyone in the future.. Basically any number of things can work, but nothing seemed to work perfectly for me without modification. Here's my end result.
    87 325es - M50 Boosted - Link to BUILD THREAD
    07 328xi wagon 6mt - daily
    • Mwishlist
      • Jul 2013
      • 505
      #62
      What engine mounts are you using? I was curious cause I think that has a lot to do with how the carrier fits but people rarely mention it. My zf carrier doesn't sit forward at all, but I am on the AKG motor mounts.
      Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
      • SirMaxximus
        • Oct 2014
        • 180
        #63
        Good point, I used the classic green motor mounts (e28 I think..) with small 1/8" spacers. e30 trans mounts + e30 crossmember.
        driveshaft sits pretty dang flat to the trans so shouldnt be much guibo stress
        • Mwishlist
          • Jul 2013
          • 505
          #64
          Cool, thanks for the info. Yeah I don't know if it makes a difference by my zf sits pretty much in the middle but I am the only one with a ZF that sits that way from what I can tell based on a bunch of posts.
