M50 trans mount
  • bblazen
    • 58
    M50 trans mount
    Would I need the tilted trans mount if I use the Getrag from e34? And can I use the stock driveshaft since its the same as e30? Or does the e34 have different mounting points or larger outputshaft?
  • mhuynh
    • Sep 2011
    • 63
    The getrag from an e34 has a larger output flange. IIRC you'll have to use a 325e, 328i, or e30 m3 driveshaft because they have the larger matching flange.
    • bblazen
      • 58
      Alright thanks. And mounting I can use stock mount?
        • 37832
        Assuming we're talking about the Getrag from a M50 E34 you can use the stock E30 trans brace.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • bblazen
          • 58
          Correct. I have a motor/trans from a 95 e34 touring. I also just planned on swapping transmission flanges so I can run the stock e30 driveshaft. Thanks for the help!
