Compression test numbers, Am I doing this correctly?
  • ZekeTheSneak
    • 1562
    So I went and checked out a s52 today. Everything looked good so we started the compression test. I wanted to compression test everything with the rings dry of oil after sitting but when I pulled a coilpack it was swimming in oil in number 4 and 5. Basically 4 and 5 were forced to be tested wet.
    Compression came out good, 123and 6 were all 190psi after five revolutions. 4 and 5 were of course higher around 210 after five revolutions.
    We then ran a wet run, everything came out to 210psi at five revolutions. They were all pretty equal on the wet run.
    Anyways I walked for the time being, The guys cool and said no rush its not going anywhere quick. Should I let the thing sit for a few days and go back for a dry run? or is everything good to go?
    I pulled the valve cover and it is in great shape. 135k on the clock.
    IMG_20170326_145655 by ZekeTheSneak, on Flickr
    Recommendations fellas?
  • digger
    • Nov 2005
    • 6072
    if 4 of them were 90psi and came upto 210 when oil was added id avoid right there
    • ZekeTheSneak
      • 1562
      Sorry I forgot the 1. Yah 194. I'll edit it.
      • pazi88
        • Sep 2015
        • 584
        That's all good.
        • Steve Corbett
          • Jul 2012
          • 449
          The oil around the plugs when you pulled the coil packs is a leaking cover gasket if I'm not mistaken.
          Steve Corbett
          1983 528E Scrapped
          1983 528E Sold
          1984 745I
          1984 325E - Sold
          1989 325I Bronzit-Sold
          1989 325I Zinno
          1988 635CSI
          • ZekeTheSneak
            • 1562
            ^yah I figured that one. Im more trying to make sure I don't get a false reading with the cylinders oiled.
