Cruise Control Help
  • Afredo
    • 349
    Cruise Control Help
    Hey guys, just completed an M50tu swap in my 1990 325i auto airbag coupe. Did a manual conversion, and would like to keep cruise control working. I believe I need to get an e36 cruise cable and attach it to the factory e30 cruise module, but beyond that I have no idea what to do. Any help would be appreciated!
    "Once more into the fray."
  • exhaust
    • Jun 2015
    • 411
    Subbed. Been having this issue for a while
    • Northern
      I like cupcakes & sh!tboxes
      • 5227
      You need 65711387004 cruise control cable (or a shorter variant if it exists.) This is assuming you're using the M50 throttle body (it doesn't fit the M52 TB.)
      With the new cable in hand, it should be fairly obvious how to unclip the plastic piece to pull it out of the actuator, then unhook the cable inside.
      Originally posted by priapism
      Originally posted by shameson
      • Northern
        • 5227
        Edit:
        look for that tab, and push it in to remove.
        • Afredo
          • 349
          Edit:
          Ok, got that much. I do have a regular M50 throttle body. The issue is though, the car was originally auto and when I did the swap I converted it to manual, so how do I get cruise to work with that being the case? I'm assuming the car needs to think it's in drive for cruise to activate, but in order to get the car to turn over I had to jump a wire or two to trick it into thinking it's in park.
