Cracked timing case cover
  • ZekeTheSneak
    • 1562
    Pulled my timing case cover off and noticed its cracked all over front and back. Should I replace it? The car was involved in a front end crash wiping out the oil pan just below the cover. Other then that i doubt I did it when removing it but who knows.
  • exhaust
    • Jun 2015
    • 411
    Yes you should replace it. It's not under pressure but it's still a potential leak point and could get worse in the future. It's a cheap enough part and a pain to get to once everything is assembled.
    • TobyB
      • 5279
      Most of those look like normal casting shrinkage marks to me, over the internet...
      t
      • ZekeTheSneak
        • 1562
        It looks pretty gnarly to me. Like it definitely took a hit from the p/o. I'll get a pic of the front. It's cracked right around the water pump which is my main concern.
        • Jb325is
          • 2137
          Yeah I would agree that those are not structural cracks, just surfacing imperfections from rapid cooling/shrinkage during casting.
          - '88 m54 coupe
          <3
          • M3PO
            • May 2012
            • 537
            That's totally normal. It's just what they look like.
            • ForcedFirebird
              • Feb 2007
              • 8300
              Yup, normal casting flash - unless they go all the way through to the front (front should be fairly smooth).
              john@m20guru.com
              Links:
