Yet another swap thread, PLEASE HELP
  • 968Reckless
    • May 2013
    • 1095
    Trying to wrap this thing up and finally drive it again. Car cranks but won't start. 1997 m3 motor sitting in a 1989 325i.
    What's been done:
    m50 manifold, harness adapter from forum member, DME tune from forum member.
    Have power to DME. No fuel (no power to injectors) and no spark to plugs.
    Cam and crank sensor are believed to be hooked up right and working (I pulled the engine out of a running car). Relays are good and I even swapped 100% working ones in. Grounds all seem to be good. Not sure where to go from here.
    Only things a physically removed:
    Purple relay, SAP stuff. The stock 325 harness already had power running there so it felt redundant. Rear o2 sensors are not hooked up and only one front is.
    FIXED: bad harness
    /// MTech Belts ///
    S52 BUILD
    M3 VERT BUILD
  • 328ijunkie
    • May 2007
    • 3961
    Who flashed DME? Sounds like usual ews if DME is powered but not firing?
    Check Us out on Facebook
    Full Product Line Tuning
    • 968Reckless
      • May 2013
      • 1095
      DesertBMW, he's been very helpful and responsive....
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
      • 968Reckless
        • May 2013
        • 1095
        Any other suggestions?
        /// MTech Belts ///
        S52 BUILD
        M3 VERT BUILD
        • 328ijunkie
          • May 2007
          • 3961
          You plugged into ecu and read codes? That will tell you 100% if it's ready to fire. Usually I see harness power/ground issues cause this
          • 968Reckless
            • May 2013
            • 1095
            Not yet, obd2 adapter is on the way.
            /// MTech Belts ///
            S52 BUILD
            M3 VERT BUILD
            • 968Reckless
              • May 2013
              • 1095
              Bump still no start
              /// MTech Belts ///
              S52 BUILD
              M3 VERT BUILD
              • raj
                • Oct 2013
                • 100
                Are you getting fuel? Spark?
                • 968Reckless
                  • May 2013
                  • 1095
                  I'm getting fuel to the rail but the injectors aren't getting power. I have no spark.
                  /// MTech Belts ///
                  S52 BUILD
                  M3 VERT BUILD
                  • raj
                    • Oct 2013
                    • 100
                    Oops, I missed that bit. Just reread the original post.
                    You said the motor came out of a running car. Did that car have the same DME tune in? That seems to be the variable that changed…wafflesI'd try another DME. Sounds like EWS…
                    Triple check grounds.. perhaps the DME needs to be grounded to the chassis. I've read conflicting reports on whether this is necessary (not in my case) but can't hurt
                    • 2mAn
                      Señior Mod
                      • 21038
                      and yet, he's not here to help or respond
                      Simon
                      Current Cars:
                      -1966 Blue Boat
                      -1969 Red VW
                      -1986 White BMW
                      -2006 Green Thing
                      Make R3V Great Again -2020
                      • 968Reckless
                        • May 2013
                        • 1095
                        I took the ECU from the same car and had it tuned by a company on here. I have a red label 413 on the way to test out. I have all the grounds covered and everything has a clean connection.
                        /// MTech Belts ///
                        S52 BUILD
                        M3 VERT BUILD
                        • 968Reckless
                          • May 2013
                          • 1095
                          I pm'd him and he's responded a few times, no complaints there. I guess I'll know more after I try the red label 413.
                          /// MTech Belts ///
                          S52 BUILD
                          M3 VERT BUILD
                          • dude8383
                            • Jan 2005
                            • 10387
                            If the car is utilizing OBD2 sensors you're not going to fire it up with an OBD1 ECU...
                            • 968Reckless
                              • May 2013
                              • 1095
                              That's what I thought but I kept being told I could....smh
                              /// MTech Belts ///
                              S52 BUILD
                              M3 VERT BUILD
