Yet another swap thread, PLEASE HELP
  • ForcedFirebird
    • Feb 2007
    • 8300
    Originally posted by dude8383
    If the car is utilizing OBD2 sensors you're not going to fire it up with an OBD1 ECU...
    Originally posted by 968Reckless
    That's what I thought but I kept being told I could....smh
    Dude is correct. If you are crafty with a pin release tool kit, you can make the harness work on either, but can't plug and play.
    Last client to bring in a hakentt/desert ecu flash, none of our standard scanners would work - not via the retro fitted interior obd port, or the BMW diag connector. Plugged an ecu in that still had stock flash, read perfect even though our wiring was blamed for the no-read. Obviously wouldn't start since ews was still enabled on the second one. Granted this was almost 2yr ago, maybe it has been remedied, just sharing a past experience.
    john@m20guru.com
    Links:
    • 968Reckless
      • May 2013
      • 1095
      Well if someone wants to lend me their ECU it would be much appreciated [emoji2]
      /// MTech Belts ///
      S52 BUILD
      M3 VERT BUILD
      • 968Reckless
        • May 2013
        • 1095
        Got the car running last night...looks like someone sold me a bad harness!
        /// MTech Belts ///
        S52 BUILD
        M3 VERT BUILD
        • sweet3
          • Oct 2012
          • 752
          Good deal! Glad you managed to figure it out in the end.
          PNP Adapter Harness Wiring for M52TU, M54, S54, M60, M62, M62TU, S62, M50, S50, M52, S52 & MORE
          • DesertBMW
            • Aug 2011
            • 1042
            I told you
            • 968Reckless
              • May 2013
              • 1095
              Originally posted by DesertBMW
              I told you
              You sure did bud!
              /// MTech Belts ///
              S52 BUILD
              M3 VERT BUILD
