What exhaust, what headers?
Open trumpet ms3 s52 vs obd1 epic off the shelf tune
://www.bimmerforums.com/forum/showthread.php?454142-E36-M3-Dyno-Sheet-Library
This is a great thread with lots of graphs. I found a few that look a lot like mine. None make as much low end torque as mine. I did find some s52 with M50 intake reviews of the epic tune and they said the samething. HUGE noticeable gains in low end torque. Up top felt the same. Perfect then for the street since I am very rarely in the 5500rpm+ rangeComment
Ok so when I put my itbs on I popped the valve cover off. I have an s52 with s52 cams. The cams are installed with less overlap. Giving me more low end torque. Losing a little hp up top. My vanos needs to be shut off earlier to compensate for this. My off the shelf tune is obviously not for this setup .will be tuned on megasquirt April 23rdComment
Or, could just time the cams correctly.Ok so when I put my itbs on I popped the valve cover off. I have an s52 with s52 cams. The cams are installed with less overlap. Giving me more low end torque. Losing a little hp up top. My vanos needs to be shut off earlier to compensate for this. My off the shelf tune is obviously not for this setup .will be tuned on megasquirt April 23rd
Most of the people who have low/less torque are because they aren't tuned or are running crazy/silly exhausts.E92 MsportComment
I like the car like this . It's a street car. With the cams timed correctly I won't make the same amount of torque at 3kComment
Yeah, it probably will. Having the cams timed wrong doesn't mean you gain 50lb-ft because you're loosing 50whp. It could mean you're losing 20whp for 5lb-ft of torque.
You either want to do it right, or you don't, its entirely possible to make the same or more torque you have down low and more power up top
Yes. My outerwear filters we're not flowing enough air. Their was a vacuum at 4k. I got some pipercross and itg's coming in the mail. Then have to make an appointment to have retuned :( pain in the ass. Live and learn I guess. I thought the outerwear filters wouldn't be restrictive. Didn't do my homework on them.Comment
