Generic m50 swap
  • clavinZERO
    Hella sick E30
    • Mar 2004
    • 2027
    Cindarella'ing your dirty engine bay and tranny makes me tired. Thanx for the new coil btw, very nice, 10hp to the wheels.
    Too anyone else interested in a swap... it looks like a lot of work, and it is, but it's really a blast. Grab a buddy or 2, some pizza, preferred beverages and some afternoons to kill and go for it. (Plus you get practice for your own swap )
    "BMW Style 32 Poster-Child"
    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
    • Erick
      Official R3V Drifter
      • 11169
      ^ True that... as one m50 swap takes place on one side of the coast.... the SE guys are joining forces on another m50 swap. :D
      ..::Support FullOpp::..
      FullOpp Stickers for sale!
      Feedback Thread
      • cahomey
        • Mar 2004
        • 1201
        it's not fair, my swap is the test dummy swap. Yours is gonna turn out to clean.
        "It's like a koala bear crapped a rainbow in my brain."
        R.I.P. Harry Goz aka. Captain Murphy
        "My ride, My ride, she don't beg, steal, cheat, or lie,
        My ride, My ride, and our relationship is classified."
        • Justin B
          Sikky Nar Nar
          • Mar 2005
          • 4273
          Awesome dude, I was gonna call you yesterday or today to see how you were doing but didnt get a chance when I ran into some serous problems with my own project. My megasquirt shorted out on my on my FINAL test, after everything was perfectly wired up, it passed all tests including the standard final one, but failed after I made an aux circuit to control the m20's 3 wire pulse width modulated idle air control valve. I think I might have a clue what happened, because I narrowed it down to two transistors that greatly increased the +12v to ground resistance. I thought they just broke a circuit that was shorting out but i realized something just recently from working all day on it. My idea MIGHT be right, but then again I could be completely wrong again (because what I'm thinking shorted out has some really significant insulation). We'll see but I'm gonna sleep on that tonight thinking good about it.
          Working on that at all tomorrow? Ive got some little stuff to do, but I'd like to come down some time and check out the progress.
          • Justin B
            Sikky Nar Nar
            • Mar 2005
            • 4273
            M50 cab? what? ;) lol... I kinda wanted to keep it an m20 but when I finish my 2002, I just might need a project.
            • matt
              • 3732
              That's how I got Ben in this whole mess, too... one minute we're planning to put an M50 into my car... a week later he's buying an S52. :up:
              • Jason89i
                • Sep 2004
                • 875
                Originally posted by Adrian_Visser
                get a load leveler before you try to put the new engine back in dude, itll be a huge bitch tryin to drop it in if you just hook the hoist to the front bracket like what u did to take it out. a load leveler will make your life so much easier.
                load leveler?? load leveler?? no way. it is near impossible to get the rear engine hook off when the motor is in the car. its also near impossible to rotate the engine with two pickup points. it took me over an hour with that stupid load leveler. then it took another 10 minutes just to pull the hook off. ive tried it a couple of ways. now its down to a 15min drop it.
                • matt
                  • 3732
                  You'll be in a world of shit when that engine lifting bracket brakes and your engine falls on your grille and fender.
                  Use a leveler. Attach it to the rear exhaust manifold and the lifting bracket.
                  • cahomey
                    • Mar 2004
                    • 1201
                    We will be using a load leveler to put the m50 in. We can drop the motor in flat because we wont have the tranny attached, but under the car on a jack.
                    • Addissimo
                      • Mar 2004
                      • 1820
                      I have it down to where I can get an m50 in using a come-along in 20 minutes by myself with the tranny on the engine.
                      You'll want to take the intake manifold off if you have not done so already. It makes things sooo much easier in the end. Take a chain and hook it to the rear exhaust & the loop near the starter, attach that to one side of the leveler, and attach the other to the loop by yer vanos unit. I'd personally install it with the tranny on- unless you've modified your tranny tunnel/firewall, you'll probably have a hell of a time getting your tools to the bolts if you try to install it after the fact.
                      The key to an easy install is to remove the intake manifold though... It'll only take you 10 minutes tops and save you a couple of hours trying to fit your hands underneath it to route hoses, remove hoist clamps etc.
                      Good luck
                      -Addis
                      Doing something M50 related? -> http://www.addissimo.com
                      On Myspace? ->http://groups.myspace.com/r3vlimited
                      BF2142 SN = BillyGoose
                      • Jason89i
                        • Sep 2004
                        • 875
                        Originally posted by Addissimo
                        I
                        The key to an easy install is to remove the intake manifold though... etc.
                        -Addis
                        skip that. my last one was installed in less than 15. keep the trans installed. keep the intake manifold installed. keep all the accessorie installed. keep the A/C mounting bracket OFF.
                        now, hang the engine off the front lift point and exhaust manifolds.
                        position the engine nearly straight up and down in the engine bay. put a large jack under the trans ouput flange. as you lower the engine, slide the jack towards the back of the car....leveling the assembly. about half way through, you will need to use only the front lift point in conjunction with the jack supporting the trans. like butter.
                        cheers, jason
                        • golde30
                          • 11464
                          cheers, jason
                          i have done swaps just like this with m20 and m42. worked very well for me.
                          dont try and attach the tranny with the engine in the bay, as mentioned above, its a fat PITA to get at the top bolts and torque them down...
                          IG: @Baye30
                          • BDSax
                            Junkyard King
                            • Mar 2006
                            • 3594
                            awesome, what a good thread.
                            Addissimo, awesome site, thanks for the info
                            • cahomey
                              • Mar 2004
                              • 1201
                              cheers, jason
                              Good post, thats exactly what I was wanting to do originally.
                              And thats what I'm gonna do.
                              • cahomey
                                • Mar 2004
                                • 1201
                                "No longer a 2-tone slut"
                                lol, the bitch got a make over.
