E36 vs E39 Accessories
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4516
    Hey all-
    The M52 I'm putting together came out of a 528 as opposed to a 328.
    Are the accessories the same/will they work fine in an e30?
    I noticed the Underdrive pulley kits have two different part numbers between 328 and 528 so I figured I'd check before I got too far.
    Couldn't find any threads about it.
    Appreciate it-
  • AWDBOB
    hooptie connoisseur
    • Aug 2013
    • 4516
    I should preface with this:
    It is obvious that both cars have different part numbers, I am only concerned with compatibility, and I can't seem to find a solid answer.
    e36 328 PS Pump: 32411093577
    e39 528 PS Pump: 32411094098
    However, all brackets/pulleys are the same p/n. Thus, I am just trying to figure out what lines to use for my PS system to mate to my Z3 2.7 turn rack.
    The alternators are also different with cooling design as well as 80a (e36) and 120a (e39).
    e36 328 alt: 12311744565
    e39 528 alt: 12317501690
