m50 3.5 inch throttle body treehouse
  • surebimmer
    • Jan 2004
    • 978
    Posted this in the for sale and didn't get much movement. Lets talk about why and why not this upgrade is worth it.
  • CMBusch
    • Aug 2016
    • 181
    Wouldn't this require a larger diameter MAF? I would think that the bigger throttle body would still be choked by a smaller MAF unless air speed makes up for it. Aside form that, what are the benefits? VAC has a kit that claims 5-10 hp but doesn't say on what specific engine. From what I understand, the larger throttle body only makes a significant difference on engines with supporting mods.
    Originally posted by Melon
    Engine work takes patience and finesse.
    Suspension work takes anger, a big fucking hammer, and a torch.
    • surebimmer
      • Jan 2004
      • 978
      Lots of peoples first modification is 3.5 inch MAF. So this would match the MAF.
      • digger
        • Nov 2005
        • 6196
        So bore of that alloy Adapter is less than 3.5"?
        • surebimmer
          • Jan 2004
          • 978
          The largest you can bore the stock manifold is just a hair over 3.25 inches.
          • surebimmer
            • Jan 2004
            • 978
            So no more talk about this? guess i will just put it on my car and have a day. Less is more.
            • Sh3rpak!ng
              • Jan 2014
              • 2667
              I'll talk about it. I've had one of those TBs sitting on a shelf in my garage with this thought in my head for ages. Can you post some more pictures? Of the throttle cable linkage? What TPS do you use? what tune? And have you been driving with this setup yet?
              Shadetree30
              • surebimmer
                • Jan 2004
                • 978
                You use the TPS on the throttle body. Never been able to figure out the throttle cable. Bought two cables from Jon at treehouse but the part number where scratched off. Anyone know how to contact him? Maybe now that he closed down he would be willing to give up the info on the OEM part number.
                • ForcedFirebird
                  • Feb 2007
                  • 8300
                  Might not have been him who did that. I get a lot of OEM parts with the numbers scratched off when buying them outside the dealers.
                  john@m20guru.com
                  Links:
                  • Sh3rpak!ng
                    • Jan 2014
                    • 2667
                    I just checked the PN for the e36 TPS and it cross referenced to the TPS on the 740, so the TPSs are the same parts.
                    Can you lay out the throttle cable you have an take some measurements and photos? I have a couple of throttle cables laying around. E36, E34 and E30 that I can compare it against.
                    Shadetree30
                    • M3PO
                      • May 2012
                      • 537
                      I made my own adapter plate (with hand tools only) and mounted an M60 throttle body to my M50 manifold. The hole in the adapter needs a slight taper because you can't open up the stock manifold to the full diameter of the M60 throttle body. You lose the stock sealing gasket so I used a little RTV to seal it. It uses the same TPS sensor that my S50 did stock so that works perfect. You must flip the TB upside down. I re-used the throttle cable that I used on my S50 swap (from a 5-series I think?). Driveability is exactly the same as the stock S50 TB without any changes to the tune.
                      I have a fully built head with valves, valve springs, big 286/272 cams, lots of port work, 3.5" TB, 3.5" MAF, custom 3.5" intake, ebay headers, 7500 RPM redline, and a full stainless 3" exhaust. Because of my other mods, I think the TB is a worthwhile upgrade. Not to mention, it just plain looks better if nothing more.
                      • CMBusch
                        • Aug 2016
                        • 181
                        While my setup may not be as aggressive, I'm still interested in this as an upgrade.
                        I have a 2.8L M50 stroker with S52 cams and 11.somthing:1 compression. I'll also be using Ebay headers and a custom exhaust.
                        However, I'm still not sure how much power I would gain. Does anyone have dyno graphs with potentially different engines/mods? How would it look better? Pictures?
