M50 swap that will blow your mind.
  • Noshow20x96
    • Dec 2013
    • 144
    Yes, I said it. This thread that I’m putting up will blow your mind. I’m not going to start this off with a story about my car and the life it went through. I’m going right in to it. I’m using a booster that’s not 30 years old....... 🤯 I’m using a booster from a e92 and this is about how I made it work.
    So I was doing some research on here and everyone is using some old pos booster that is 1 expensive and 2 way to much work to make it fit (in my opinion)
    Someone on here was mentioning about sizes of boosters and the e9x one came up. 10” in size. So I kept that in mind. Was search on eBay for boosters and all the ones that people use for this swap was so expensive, $200 $400 $600. Like out of this world prices. The e92 booster came up, comes with master, reservoir, lines and gasket. Looked a bit weird but it looked like it would fit. At the price of $50 I said fuk it let’s try it and if it doesn’t fit, it was $50.
    Now, a couple days later go by and I received the booster. Looks good, No damage at all, no signs of leaks. Now I’m comparing to the old 27 year old booster. The studs that goes through the firewall look the same. Missing two but it will work. So I put it in the firewall and goes right in. The lines for the master are on the other side. No big deal. Go take a look to see where the pedal lines up and guess what. Right on the money. Now I’m seeing the pin that puts them together has to be longer. So I made one.
    Now it’s bolted up.
    So now I’m testing things. I put the brake lines on the master, the e9x master is a 12x1 compared to the old master that is 10x1. E39 has brake fittings that are 3/16 hole but 12x1 thread. So I Bubble flared it and was done with that. You can also find the brake fittings at your local auto parts store.
    Now the lines are done. Pedal to the rod is done. Now to test if the engine will fit and it did. With minor issues but 1/2 clearance from the intake manifold to the booster. The brake reservoir is hitting the TPS. so I took a e34 530/540i remote reservoir and clutch reservoir and put it in the car. You can also raise the reservoir with some modifications and clear the TPS. Now to test if the engine vacuum will Work with this booster, I’m doing this because e9x use a mechanical vacuum pump. So I did and OMG. that nasty, spongy, old brake pedal is gone. I mean, it feels like a brand new car brake pedal.
    I also want to mention that this will also Work great with the stock m20, m10 or m42 maybe even the s14 it could probably work with a s54 swap to.
    Now I hope that this can be Another option for you guys and I hope that you guys don’t jack up the prices of the booster. There is no reason for it.
    If you guys have any questions or need any help, hit me up here or give us a call at globo auto in south river NJ
    Here is a update with all the parts that you will need to do this
    Find the other parts at fcpeuro.com
    E9x booster (find on eBay)
    Clevis pin (I custom make them)
    Brake fittings 12x1 3/16 I.D
    Bmw brake master reservoir grommets x2
    Bmw brake hose connector x2
    Bmw hydraulic hose x2
    Bmw brake fluid reservoir x1
    Thank you razo-s.supra for finding the parts
    Here is his setup
    Here is a little background of the build and some pictures.
    1987 bmw 325e 164,000
    M50B25 nv 136,000
    ZF 320 trans 180,000
    JB lighten flywheels 240 mm
    95 m3 clutch kit stage two 240 mm
    ZHP shifter
    Condor tall weighted shift knob
    E driveshaft
    3.73 LSD
    Fortune 510 coilovers with swift springs 14k front 18k rear
    RX7 FC brake kit front
    Stock brakes in the rear
    I made 3/4” spacers for raise the motor above the subframe
    RED46 m30 skid plate
    E90 335i booster
    E34 remote brake and clutch reservoir.
    Turner overdrive pulleys
    Reseal engine
    Removable radiator support
    Z3 radiator
    Spal pusher fan 2100 cfm
    Mishimoto Radiator hoses
    325is coolant reservoir
    Fully custom exhaust with v-bands, true dual with x-pipe and borla muffler 2.25 diameter
    Turner ecu chip
    Wired x20 connector
    Reinforced front subframe
    E46 m3 rack and pinion
    16x9 +15 Schmidt modern lines with 225/40R16
    Probably some more stuff that I’m forgetting
    Added photos
    Rx7 brakes are awesome with this booster
    Sent from my iPhone using Tapatalk Pro
    Onwer of
    1987 e30 325e soon to be s50
    1991 e30 318i four door
    1994 e34 530i 5speed
    05 e53 X5 4.4i fully loaded
  • Noshow20x96
    • Dec 2013
    • 144
    Originally posted by 36brua
    B f d
    [emoji106]
    Onwer of
    • wworm
      • Dec 2016
      • 1719
      more pics of the car! Got any more detail pics of the booster in place?
      1984 Delphin 318i 2 door
      • Noshow20x96
        • Dec 2013
        • 144
        I will when I get to my car. I forgot to take some final pictures. I was to excited to drive it.
        Onwer of
        • SterlingMetE30
          • Mar 2014
          • 229
          This will be nice just to use for a newer option for even an m20.
          Sent from my SM-G930T using Tapatalk
          • Noshow20x96
            • Dec 2013
            • 144
            Let me know if you would like to have some pins made.
            Onwer of
            • SterlingMetE30
              • Mar 2014
              • 229
              Will do man. Perhaps i will consider this when i get my 885 head rebuilt and ready for my 2.7i swap.
              • wworm
                • Dec 2016
                • 1719
                So would you say this makes the braking response more crisp? Does it require less effort at the pedal to slow down than with the stock booster?
                • Noshow20x96
                  • Dec 2013
                  • 144
                  Yes to all the questions.
                  The e30 doesn’t feel like I’m driving a 31 year old car anymore. It’s very responsive, predictable pedal, smooth braking even with the RX7 calipers. I would recommend this booster to ever single e30 owner out there.
                  Onwer of
                  • wworm
                    • Dec 2016
                    • 1719
                    Good to know. Thanks for making this post
                    • Noshow20x96
                      • Dec 2013
                      • 144
                      [emoji106]
                      Onwer of
                      • DesertBMW
                        • Aug 2011
                        • 1020
                        looks good, just don't like the overspray
                        • DrJosh
                          • 2011
                          This is perfect timing for me. I am gathering parts for a M54 swap and have been looking through my braking options. I just pulled the trigger on one off ebay. These things are cheap.
                          Do you happen to know the e90 master cylinder specs compared to the E30 one?
                          Originally posted by Sonny
                          I am a meme for our community.
                          • ZekeTheSneak
                            • 1562
                            What is the diameter of this booster?
                            • Noshow20x96
                              • Dec 2013
                              • 144
                              Thanks man. Yea I forgot to tape off some spots, it will be cleaned off later.
                              Onwer of
