Quick driveshaft question
  • E's-30
    • Feb 2017
    • 35
    Currently swapping a s52 with ZF into my e30. I acquired a small case 3.46 rear diff out of a e36 318ti(4bolt). Can I use the standard zf driveshafts 328/m3 with the rear of the e30 shaft or will the length be changed because of the small case diff?
    I have searched a ton and can’t find an exact answer and don’t have time to waste buying the wrong driveshaft.
    Thanks for your help!
  • reelizmpro
    • 9543
    The length is slightly adjustable so it should work. However, you don't want to use a small case diff with the S50/S52 anyway.
    88 M3 - LACHSSILBER
    89 M3 - ALPINEWEISS II
    • E's-30
      • Feb 2017
      • 35
      Thanks, good point!
      I’m going to rebuild my medium case and put it back in, this one was too good of a price to pass up. It’s also the 3.46 and according to metric mechanic should be good for 280ft/tq so I think I’ll be alright for at least a little while.
      • TobyB
        • 5265
        I'd be a bit surprised if the 168mm diff can withstand an S52 for all that long-
        keep in mind that your gearbox is a torque multiplier, so 280 ft/lbs at the crank
        becomes 280x4.2 ft/lbs in 1st gear...
        So no long smokey burnouts for you!
        heh
        t
