s52 swap keep ruining alternators
  • mtech325
    • May 2008
    • 568
    Hi everyone,
    My obd1 s52 91’ 318is seems to be chewing through alternators at an alarming rate. This will be the 3rd Bosch remanufactured alternator that has failed within the last year (around 10k miles). The battery light on the dash has illuminated again, so I checked to see if the battery was charging using a multimeter and it’s reading below 12 volts. With the car off, the battery shows around 12.2 volts.
    I’ve checked my alternator wiring and all seems to look fine. I made sure to clean the contacts and ensure all connections were securely fastened upon install of the alternator a few months ago. I’m not an expert when it comes to electrical systems, so is there something else on the car I should investigate?
    Thankfully I have a spare rebuilt Bosch 140a alternator on hand, but I don’t want to continue throwing new parts at the car instead of fixing the issue.
    Any help or pointers would be greatly appreciated.
    Thanks,
    Joey
  • AndrewBird
    The Mad Scientist
    • 11898
    Do you have a aftermarket stereo or anything that would put excessive draw on the electrical system? Have you accidentally killed the battery recently by leaving the headlights on? If you have a dead battery and just get a jump without re-charging the battery out of the car, it can overload the alternator and kill it.
    • mtech325
      • May 2008
      • 568
      I'm still running the stock radio deck and speaker setup, so no aftermarket audio stuff. I can't say I've killed the battery recently either, but I did let the car sit for about 6 months before putting it back into daily driver status a little over year ago with the same battery (battery is dated 2015).
      • e30austin
        • 15382
        If your reman alternators came from IMC (if you know or not), try ordering from a different source. I had quite a few bad starters and alternators from them in the last couple years (just had to throw away the reman Bosch starter in my E39 on Saturday, coincidentally, a reman part that came from IMC) - would also advise buying a new (not reman) unit and see what happens. Otherwise, it's a fairly basic system, overall. Best of luck and post here if you have more issues.
        • MrBurgundy
          R3V Degenerate
          • Mar 2012
          • 5562
          I know there's an 80 and 140 amp alt for these cars.
          Are you sure you've been installing 140s on the car?
          • ForcedFirebird
            • Feb 2007
            • 8300
            The problem with reman alternators is they are being sent overseas and they are not replacing the regulators. The windings hardly go bad in an alternator - just take the plastic cover off the back, 2 screws and the regulator pops out. Whenever a customer comes in the shop with a bad alternator, I go straight for the regulator - replace it and 9/10 times it works perfect for years to come, if not then I get a reman alternator and use the new regulator in it.
            As far as them coming from IMC, I am pretty sure all the major suppliers are only using a few different companies and just putting them in their own packaging. Weather it be WorldPac, IMC, Advance Auto etc, most of them are using Cardone or Reliance rebuilds.
            If you have a Bosch, regulator is part number 12311747920, Valeo is 12311747920. If you shop around you can get them for about $50-80.
            john@m20guru.com
            Links:
            • e30austin
              • 15382
              Just saying, the issues I was having, was after IMC got purchased by Parts Authority, and was exclusively ONLY to parts purchased from IMC. It happened too many times to be considered a coincidence. Just saying, it is definitely a possibility and I'm not the only person who noticed the issues and the frequency of them.
              • mtech325
                • May 2008
                • 568
                I have tried both in the car. The first was a rebuilt 80a, then I installed a 140a, and currently have an 80a in the car again. The good news is that the 140a isn't much larger than the 80a for fitment within the e30, but the Z3M thicker radiator makes in-car removal very tight (long bolt has just enough room).
                Thanks ForcedFirebird for the info on the regulator. When I got home from work, I decided to open up my spare "rebuilt" Bosch 140a alternator, and the regulator definitely did not look new. Looks like a NEW regulator is the first order of business.
                • thedentonmare
                  • Jan 2016
                  • 60
                  Post back and let us know if that worked out for you! I've yet to have to change out my alternator, but just learned that there are two varieties! Thanks all.
                  • Gregs///M
                    • Mar 2012
                    • 2459
                    I will give some input in the case that the alternators you are buying are of good quality and have their regulators replaced with new. Some issues that may cause premature failure of an alternators output are as follows:
                    -Improper grounding of alternator.
                    -Poor condition of engine ground, this cable grounds all engine electronics including starter and alternator and all sensors. Its very important for this cable to be in great condition.
                    -Defective dying battery. If your battery is 5 years or older, I would consider replacing it. Like mentioned above, if the battery died, it will cause more demand from Alt. Sometimes when batteries die, they can still hold charge, start the car, but be damaged in a state in which they will have difficulty charging up, damaging your Alt in the process.
                    -Short in output cable. There is a heavy gauge cable that runs from the Alt to the starter. If this cable is old and the insulation has broken down, there could be a small bleed to chassis ground, causing Alt to fail in its charging output. This is more rare but not impossible.
                    Owner - Bavarian Restoration
                    BMW and European Electronics Repair and Restoration
                    www.BavRest.com
                    My Feedback Thread
                    Our Facebook!
                    Follow our Instagram!
                    • mtech325
                      • May 2008
                      • 568
                      Thanks for all the advice. As an update, I ordered a new voltage regulator and swapped it into the existing alternator, but that didn't solve the problem. When that didn't work, I ended up going with a known working genuine BMW 140a alternator, swapped the new regulator into that and the car charging system is working once again. Since my battery was pushing 5 years old, I replaced it with a new one as a preventative measure.
                      • NeverEnough02
                        • Mar 2015
                        • 224
                        Where are you finding these for $50-$80? I am only finding them for around $170. I was thinking about replacing the contacts in mine ($18).
                        • ForcedFirebird
                          • Feb 2007
                          • 8300
                          Shop around for "e36 voltage regulator" ;)
                          I have them here in stock and they are no where near $170 unless you buy them from BMW. Hella, Bosch and Valeo all make replacements.
                          john@m20guru.com
                          Links:
                          • NeverEnough02
                            • Mar 2015
                            • 224
                            I have tried it all. The one I need is bosch 1 197 311 238. It is different than the valeo ones which are all over for $45. Want to ship me one if you have it?
