M50E30 engine mountings
  • tjhartge
    • Jun 2004
    • 86
    Originally posted by tonytony
    i have e34 rubber mounts and everything is lined up and it's driving. just get the e28/e34 green bell pepper looking mounts
    tony,
    does the engine have excessive movements?
    was going to fabricate some aluminium cup mounts, but will first gauge the design, and if its really worth getting it fabricated
    or should i just get urethane e34 mounts?
    • tonytony
      Knee deep in poopie
      • Jan 2004
      • 3498
      the engine barely moves when i rev the engine up, the e28/e34 mounts have steal carriers that the rubber sits in which limits the about of compression of the rubber
      • alexbaby88
        • 219
        Originally posted by joshh
        I don't believe anyone makes Poly that will work for the S/M50 motors yet. Turner doesn't even sell any poly.
        Ireland lists urethane motor mounts for E36 6-cyl cars ie M50/52 engines.
        • DanThe
          • Mar 2006
          • 98
          Originally posted by tjhartge
          Yes unfortunately, my swap was abit more complicated due to the larger than normal 6 speeder box, had to do abit of weaving and tunnel mods to prevent the box from hitting the tunnel.
          Mine sits abit more infront compared to my other pals m50 conversions, causing the tight space between the rad n fan, due to the tropics, i need to run both fans - did a test just running the aux fan alone,the temp went way up to 3/4 and it scared the shit out of me......
          so back to getting the motor mounts firm yet flexible without flexing too much, thats why the idea of the aluminium cups came about
          The e30 motor mounts had them, but none for the e34, was just thiking of fabricating the cups up to 3/4 the length of it to reduce movement.....
          Out of interest, what 6spd box are you using?
          • tjhartge
            • Jun 2004
            • 86
            Euro E36 M3 Evo, shares the same bellhousing bolt pattern for all the M5xxx engines
            • Mr.SWISS
              • Nov 2005
              • 1251
              OK WTF is the deal with these mounts? I ordered e28 M5 mounts and got 2 different ones. One black angular one like I have seen in pics, and this one.
              Originally posted by 325Projectz
              don't listen to the diagram... listen to mr. swiss.
              :nice:
              • FredK
                • 14763
                Those mounts must be HOTTTT for you to have a potholder right behind it. :mrgreen:
                There are two styles of mounts. The M5 ones are the green ones with the metal brackets. The cylindrical one is a 535i mount. At least, that is what I recall when I ordered mine up.
                • Mr.SWISS
                  • Nov 2005
                  • 1251
                  This is the same image he pulled up at the shop. They use two mounts on the m5&m6. Angular one on the resting side, Big stiff solid one on the torque side.
                  :nice:
                  • FredK
                    • 14763
                    Hmm, weird. I dunno dude. I used two of #12 and my engine sits fine.
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      We need to update the wiki to reflect this for our future swappers. ;)
                      :nice:
                      • tonytony
                        Knee deep in poopie
                        • Jan 2004
                        • 3498
                        i used the two bell peppers also, works fine for me
                        • 02stu
                          • Jan 2005
                          • 872
                          I was looking around for stiffer engine mounts while I was doing my swap but now that I have seen how stiff the e28 mounts are I know why no one offers poly mounts. The whole car shakes before the engine does.
                          • Bimmer335is
                            • Jun 2006
                            • 146
                            my IE urethane bushings, I think they are from an e28 m5, are working fine. I'll show pics soon.
                            • tjhartge
                              • Jun 2004
                              • 86
                              cool, pix as soon as you can, i get alot of flex when i hit corners hard, i need to upgrade my current ones that are from the e34 to a much stiffer and firmer ones, btw how much do the IE ones cost?
                              • Bimmer335is
                                • Jun 2006
                                • 146
                                You can get the e28 5 series urethane motor mounts from IE for $98 a pair.
