735i brake booster/cylinder
  • BigD
    • Jul 2006
    • 1085
    So does anyone else realize that the 735i brake booster/master cylinder is the exact same booster as the iX, and the exact same master cylinder as the E34 M5??? Everyone seems to be hounding for only those two specific ones, which are uber rare used, when you could simply find a junker 735i and have the complete assembly....
  • Bimmer335is
    • Jun 2006
    • 146
    I realized that after first buying an ix booster and then buying the 735 booster that looked better, and then was going to put a new m5 mc on it. oh well. So, the final verdict is, just get the e32 735 booster mc assembly and you'll be happy.
    • BigD
      • Jul 2006
      • 1085
      I realized it when trying to search for the part numbers of the two components and found a site that listed their compatibility for the 3 cars. P/Ns alone are fine if you are buying new, but when you are looking for people parting out cars, trying to find someone with an iX or M5 is a "bit" harder than someone with a 735.
      • Mike325
        • Mar 2006
        • 3685
        Cool. I have heard about this too but was not sure about it. Thanks for the heads up.
        Originally posted by Kershaw
        • BigD
          • Jul 2006
          • 1085
          FYI I just found a 735 being parted, got the booster and MC assembly for 80 bucks.
          • matt
            • 3731
            FYI: It won't fit straight in place of an iX unit... the fork that connects to the brake pedal is different, and needs to be changed to the iX one.
            • ZiMMie
              • Jun 2004
              • 968
              the fork from ur current booster should work.
              it doesnt need to be from an IX.
              www.stancefactory.com
              • LINUS
                • 2422
                Cool, now you can afford a haircut.
                Or a black rubber band.
                It's not how you handle the good times, but the faith you keep in the bad that defines you.
                • matt
                  • 3731
                  True. Shoulda thought of that.
                  • BigD
                    • Jul 2006
                    • 1085
                    Try this instead:
                    • LINUS
                      • 2422
                      Nicely played, my friend. So what's up with the haircut tho - really? I'm no fashion whore either, but that's pushin' it.
                      • BigD
                        • Jul 2006
                        • 1085
                        The rules to join the PNW Crew is you have to provide a goofy picture of yourself for identification... so there it is. :)
                        • trucupey
                          • Feb 2007
                          • 95
                          Which 735, e23?
                          Out of which 735 and what year reange?
                          Alex
                          • BigD
                            • Jul 2006
                            • 1085
                            Alex
                            Don't know about the E23, but any E32 735i/735iL for sure.
                            • trucupey
                              • Feb 2007
                              • 95
                              Thank you
                              Thank you
