How the Frankenmotor Became an S50
  • triggrhaapi
    • Feb 2007
    • 350
    M50 block was tapered, so I decided to bore it out and use S50 pistons and just make the damn thing an S50. I got my S50 pistons as a mix and match set for around $400, far cheaper than $1000 for JE or factory oversize M50 pistons, which wouldn't have fixed the taper anyhow.
    Let the glamor shots begin!
    Oh and that's the red devil himself minus one M20 motor. Bimmerfest or BUST!!!
    That used to be an M50 block, once upon a time, but now, it's an S50 block, and those pistons didn't used to match either. I had them balanced and the wristpins polished.
    More automotive porn.
    One more shot with my dirty garage couch, on which I smoke hookah and/or store parts. One day it will be a porch couch, but that will have to wait until I'm sure the rainy season is over.
    /Porn. More to come soon, with assembly and some more shots of the little red E30 hooptie!!
    1987 BMW 325is | Frankenmotor S50 | Supersprint Replica Headers | K&N Intake | Gutted Stock Midpipe | Zimmermann Rotors | Stainless Brake Lines | Porterfield Racing Pads
  • triggrhaapi
    • Feb 2007
    • 350
    Still waiting to get upper rod bearing shells and piston rings, along with other essential engine parts. Until then, I've installed the crank and torqued the main bearings.
    First, you need to install the oil squirters back into the upper bearing in the crankcase. This is how they look installed:
    In case you're wondering, this is what they look like when not installed. They are about ten bucks each and hard to find so I recommend not losing them.
    Here's the freshly polished crankshaft. It will soon be covered in grease and not pretty, so I thought I'd take a shot of it in it's glorious state.
    Here is the block, now turned on my engine stand so I can drop in the crankshaft. On it you will see the as yet unopened bearing shell set for the main bearings.
    First we lubricate the bearing shells and then press them in. The ones for the upper bearings have two holes and can only be lined up one way. The thrust bearings, the larger two bearings, go on the second bearing from the back of the motor, between cylinders 6 and 5. They can ONLY be placed here, as the crankshaft only has thrust bearing surfaces on this bearing.
    Next we place the crankshaft into the block and lubricate it, turning it once 180 degrees and lubricating it again with assembly lube. We also install and lubricate the lower bearing shells keeping in mind that there is a specific thrust bearing cap. Once these are all done, place them and thread the appropriate bolts. In my install, there is no pickup tube support bracket, but there is for E36 versions of this motor, you can ignore this bracket if building for an E34 or E30, as the pickup tube is shorter and needs no bracket.
    Now we need to torque down the main bearing caps. Just so all of you know, this is NOT covered in the bentley manual. I had to go searching to find the appropriate torque specification. Torquing is two stages, the first is 20 nm, then a torque angle of 50 degrees. This means that you torque it first to an initial spec and then turn the bolt an additional 50 degrees.
    We're done for now. Hopefully the parts will be in and the build can continue as planned today. I will be covering piston to rod installation, as well as piston and rod install to block, oil pump to block and crankshaft, and time permitting, cylinder head to block installations. I'll be covering this whole motor build documented every step from parts to completion.
    • triggrhaapi
      • Feb 2007
      • 350
      Didn't get parts yesterday, so I prepped the chassis!!! Hooray for me and Joe!!
      Here are a few shots of the cleaned up engine bay.
      Here's a shot of the freshly installed IX brake booster and master cylinder.
      Here's the shot that shows the mounting bolts and nuts for the IX booster. Pain in the motherfucking ass to get to. Joe had to contort and fold himself into Samus' Ball form to get them undone and redone.
      Here's some shots of some of the new leather ///M stitched goodies I got...
      One more shot with some foreshadowing. I hear that makes the story more interesting.
      • FredK
        • 14761
        What rings are you using, Schoettle, Deves or something else?
        • triggrhaapi
          • Feb 2007
          • 350
          OEM so I would imagine they are Mahle or something of that kind. I'll post a picture when I get them later today.
          • FredK
            • 14761
            Where'd you get the rings, just curious?
            • triggrhaapi
              • Feb 2007
              • 350
              Legend Import, an OEM parts supplier. I ordered them straight off of the part number from realoem.com
              • Beej '86 325es
                • 2639
                haha your clutch master cylinder is gay
                -Brandon
                '86 325es S50
                '12 VW GTI Autobahn DSG
                '03 540i M-Sport (sold)
                '08 Jeep SRT-8 (sold)
                For sale:
                S50 TMS chip for Schricks
                • FredK
                  • 14761
                  • triggrhaapi
                    • Feb 2007
                    • 350
                    Not really. I know the 535 or whatever MC is supposed to be better, but who cares, I got both the booster and MC as a package deal for way cheaper, and it was designed to work on an E30, so I don't see the issue.
                    Plus, my engine will be built today, unless your sig is a dirty liar, that makes me better than you :-P ;)
                    • Beej '86 325es
                      • 2639
                      Just messin' with ya dude. :) I there's lots of gay parts on E30's...
                      Clutch master cylinder: made by FAG
                      Transmission: made by Getrag (Gay-trag)
                      should have my engine back from the shop in about a week though. :D
                      -Brandon
                      '86 325es S50
                      For sale:
                      • triggrhaapi
                        • Feb 2007
                        • 350
                        Sick!! I'm messin right back, man. I'm on the "Make it to bimmerfest" suicide mission right now....
                        • PiercedE30
                          • Apr 2005
                          • 4220
                          Very nice to see an update on your motor triggrhaapi, I am in the tear down/acquire parts/check clearances/send parts to the machinist stage right now. I am looking forward to watching this unfold.
                          My 2.9L Build!
                          • PiercedE30
                            • Apr 2005
                            • 4220
                            So, is it stock compression (for an S50) or is it higher?
                            Oh, and I just scored a S50 crank......
                            My 2.9L Build!
                            • mazur
                              • Jan 2006
                              • 731
                              Stock is 10.5:1
