Tried to fit a 535i airbox... (lotsa pics)
  • static
    • Oct 2005
    • 501
    .. and it ain't fittin' easy
    1. lower part is touching alt and hoses underneath that go to the res. Also it kinda interferes with TB levers/cable, but could be mounted to clear them (i hope)
    2. so looks like teh bottom part needs to slide a bit towards the rear, as otherwise the top doesn't clear the hose
    3. this is what my underneath looks like
    4. so i slid the bottom a bit away from the rad and thgats how it looks with top on
    5. Notice how retardedly close (and awkward) the outlet is to the TB
    6. so close to the hose. I figured i can perhaps cut a piece from the top to be able to slide the box more forwards and clear the hose - then fiberglass the hole (so it would kind of go around the contours of the hose)
    7. from the pass side angle
    8. and another
    needless to say the fitment is pretty :giggle:, so we shall see
  • amdspitfire
    • Mar 2006
    • 254
    any snorkel for fresh air?
    • static
      • Oct 2005
      • 501
      seeing how the apperture directly hits the rad side, i guess i'll have to make one (probably on the bottom)
      • e30_kid89
        • Apr 2006
        • 489
        it would fit much easier with the guys running m42 rads....i think... heres the pic again for comparision??
        • Bmjpv
          • Mar 2007
          • 561
          a/c install
          I've been working on this for the past week.I know it will work, but here is what I've done so far. Removed the abs (thicker) mounting bushing and installed some a/c mounting bushing (thinner)to move abs unit further towards inner fender. I've got the a/c box bottom cut flat tappering forward which lowers and lines up with the stock fresh air neck. I've also had to remove and reangle upwards (about 20degs) the inlet radiator neck.I'm not using the stock plastic tanked radiator and am able to modify as needed. I'm using uv resin with glass cloth to mold in areas. UV resin is very trick,look into it. I'll post pics along the way. joe
          • amdspitfire
            • Mar 2006
            • 254
            Originally posted by Bmjpv
            I've been working on this for the past week.I know it will work, but here is what I've done so far. Removed the abs (thicker) mounting bushing and installed some a/c mounting bushing to move abs unit further towards inner fender. I've got the a/c box bottom cut flat, which lowers and lines up with the stock fresh air neck. I've also had to remove and reangle upwards (about 20degs) the inlet radiator neck.I'm not using the stock plastic tanked radiator and am able to modify as needed. I'm using uv resin with glass cloth to mold in areas. UV resin is very trick,look into it. I'll post pics along the way. joe
            what are you trying to accomplish with this airbox?
            • Bmjpv
              • Mar 2007
              • 561
              filter
              What I want is the coolest incoming air and I'm getting this off the orginal outlet next to radiator . I get the largest surface area that I can, and a toned down induction system. I like that somewhat factory look too.
              joe
              • static
                • Oct 2005
                • 501
                ^^ aren't we all looking for the same things with this box?
                (it's funny how ricers tend to ditch their airboxes for cones and we try to do the opposite - retrofit the stock airbox)
                • asubimmer
                  • 6482
                  so a cone filter makes you a ricer? why do most race cars have cone filters then?
                  • static
                    • Oct 2005
                    • 501
                    don't feel like arguing, but logically:
                    "all ricers upgrade to cone filters" != "whoever upgrades to a cone filter is a ricer"
                    counter-proof: "I use a cone filter but i am not a ricer" :finger:
                    it's just that using a cone filter inside a hot engine compartment WILL make you loose power (from my first hand experience anyway), since warm air is less dense than cold. Of course one can place a cone filter in an area where there is only cold air - but it's a bit hard to do on a swapped e30.
                    • asubimmer
                      • 6482
                      so build or buy a heat sheild...
                      but most race cars don't even bother w/ a heat sheild. Honeslty you have other things to worry about. Put a cone filter on there and be done w/ it.
                      • matt
                        • 3731
                        Funny and smart.
                        Define most race cars?
                        I am going to put an airbox on mine so that I can use a paper filter. They are FTW.
                        Again, define "most race cars." Most good racecars have ducting to the engine intake, or an airbox. Most clubracers have heatshields.
                        What is more important than power? :woowoo:
                        • Bmjpv
                          • Mar 2007
                          • 561
                          a/c
                          The cars that run up front in a race spend the time and do this right! Everone else is a also ran or a backmarker ( back marker means your going to get lapped). This all takes time to do it right but I think I'll get what I want in the end. I'll try to show progress tomorrow with pics.
                          joe
                          • static
                            • Oct 2005
                            • 501
                            ^^ awesome, can't wait
                            • Bmjpv
                              • Mar 2007
                              • 561
                              Here are the pictures as i've promised.
                              Bottom half of airbox sitting on framerail:
                              Inlet Snorkel for lower half:
                              Upper Half Mounted with e36 Elbow in place:
                              Side shot to show airbox and radiator positioning/modifications.
                              Upper Half Flipped Over to show rubber Elbow Fitament:
                              Spacer off TB that was made from an e36 gutted MAF:
                              i'm about 90% done i just need to get some lathe time to massage the inside of the adpater and open it up to allow it to fit better over the TB.
                              For the rubber elbow I cut a hole in the upper airbox and made the diameter very snug to the elbow to eliminate any leakage. the actual MAF will be a euro 3.5"/540i type and will be placed inside the upper airbox half.
