Tried to fit a 535i airbox... (lotsa pics)
  • static
    • Oct 2005
    • 501
    #46
    here are some pics of my progress (thanls goes to Joe for inspiration)
    (^^ looks like enough space for air to move around under the filter)
    enjoy,
    Alex
    • Bmjpv
      • Mar 2007
      • 561
      #47
      air box
      Static, That's a good idea that your running with . What I was trying to do in fitting that lower box, was that I looked at it as a static pool of air to be drawn from,also the most direct inlet for incoming air. I know how tight that area is we're working in. I'll get some finishing pics up today ,more food for thought . Your set up is going to look really trick! joe
      • static
        • Oct 2005
        • 501
        #48
        Thanks
        actually i was a bit disappointed yesterday when i tried to fit it again. My ABS is in stock location (i just got rid of some fins that were coliding with the abs lines) and i also got rid of that tab that holds the smaller coolant hose that goes towards the engine side - it was interfering with the box quite a bit. I can see you also moved that hose over on the other side of the a/c box holder - good thinking.
        So now it's a bit better but still no cigar. I HAVE to mod up the upper piece to clear my rad hose. I think your hose nipple is higher up that the one on stock 325 rad. But i don't see it as a big endeavor.
        • Bmjpv
          • Mar 2007
          • 561
          #49
          Which to use? I went with the afe. others are OE filter(r) and k&n (l)
          540 meter
          right side of air box
          finished engine bay
          fast and faster,which is which?
          • BDSax
            Junkyard King
            • Mar 2006
            • 3594
            #50
            sweet, now i need to find me a airbox
            • BDSax
              Junkyard King
              • Mar 2006
              • 3594
              #51
              what is a resonable price of these airboxes? theres a company down here that has a bunch of them
              • Bmjpv
                • Mar 2007
                • 561
                #52
                a/box
                I do pick'n pull, 30min away and I've been paying $7-20 for the box with oe filter. joe
                • rede30
                  • 4697
                  #53
                  that looks good, I may have to copy this. Now spray that with some trim paint and call it a day.
                  • Bmjpv
                    • Mar 2007
                    • 561
                    #54
                    dirty air box
                    Ya that's the stuff put on the plastic by the factory (turns yellow) I've got a little more fit & finish and than I'll slap some paint on the setup and done!. joe
                    • Bmjpv
                      • Mar 2007
                      • 561
                      #55
                      bump
                      • e30polak
                        • 6136
                        #56
                        very nice setup, how's it drive with it? looks nice and factory :mrgreen:
                        INSTAGRAM: @UNDR8D_EMPIRE
                        • Bmjpv
                          • Mar 2007
                          • 561
                          #57
                          bump
                          • FredK
                            • 14763
                            #58
                            anyone try the M42 stock airbox? I think Chuck90m3 did, but I can't find any details on how to make it fit.
                            • btec116
                              • Jun 2007
                              • 131
                              #59
                              Hey guys,
                              Nice work, very clean.
                              Just a thought, has anyone tried a heatgun to mould the airbox into shape? I know this works with some plastics, and wanted to try it myself. Would be prefect for clearing the rad hose with the lid.
                              Also, this is probably obvious, but I thought this airbox was only on the E32 7 series. Does it also come on the 5's? Which ones (E28/34?)?
                              This is my first post, so thanks for reading!
                              • static
                                • Oct 2005
                                • 501
                                #60
                                on e34 535i AFAIK, i think on e28 they are different, look at realoem.com
                                Don't think heat bending will work. This plastic is designed to be close to exh manifolds on a 535i (on the other side)
