Motor is in but have issues !
  • ericzz
    • 286
    So far the IX booster is hitting the shaved obd 1 manifold . the fuel lines are hitting the booster , the upper heater core hose looks as if it will never fit . I tried a shim under the Drivers side about 7/16 and it helps the manifold to booster clearance . Could someone post a few close up shots in and around you IX booster master with no shims .
    I have e28 m5 grey mounts left and right with e36 arms .
    trans is all lined up shifter and driveshaft are fine .
    With so many using the IX set up I must have something off a bit
    HELP !!! THANKS
  • BeirBrennerE30
    • 2740
    the 320 booster gives you more room... bend the heater core hoses down and away from the engine to give more room(be careful they are brittle). use rubber flexable fuel lines that miss the booster and just keep frimmin the manifold to get it to fit. It SHOULD fit with out shimming.
    e30sport.net
    '06 M3 Competition - 6-speed
    '97 Range Rover Vitesse
    • BingM3
      • 863
      Two options 320 booster or Geo Prizm
      • ericzz
        • 286
        I just ordered a 320 booster . I will install friday .
        • Mike B.
          • Jan 2006
          • 987
          The Porsche 924/944 boosters are a better option than the 320i booster. The shaft is already the same thread pitch as the E30 and just needs to be cut down to fit.
          The days of recommending the 320i booster should be over.
          • FredK
            • 14761
            I wonder what the 924 booster will feel like? That's the one unknown, but I guess with a vac can that you can get a little better feel, right?
            I saw in the Euro motor booster setup thread that you're going to go with that custom dual master setup. TRICK!
            • golde30
              • 11464
              HELP !!! THANKS
              interesting. i have those same gray mounts, and will be using an IX booster. im dropping the motor in next week. i guess i will see.maybe we should measure the gray mounts, and the green mounts. could be a lil different...
              IG: @Baye30
              • Mike B.
                • Jan 2006
                • 987
                The 924 boosters came in two sizes based on what I found in the Ate catalog, 8 and 9 inch dia. Early builds got the 8 inch and later builds got the 9 inch. Both have the same shaft dia. and thread pitch as the E30.
                I feel that the 8 inch booster with the stock master cylinder and the vacuum reservoir would provide a very acceptable pedal.
                The dual master assembly the I am having fabbed up will less than 8" long (including the masters), think 4x4x8 box for a rough fitment guide. It will be bolt-in and require no fabrication what so ever.
                I am going to be making these on an "as needed" basis, but if I can get a few interested parties, I should be able to offer them with some sort of "group buy" discount.
                • Garageaholic
                  Freestyle Fabricator
                  • Dec 2005
                  • 5204
                  Any pics of your '89 M3 cabrio?
                  Is it real or replica?
                  Recent Rebranding!!
                  E30 SM62/S62
                  E30 M60 V8
                  E30 M30 Big 6!
                  Instagram.com/garageaholic
                  Youtube.com/garageaholic
                  • ericzz
                    • 286
                    Its a red replica I built in around 2001 sold it on EBAY to a guy in INDIANA and regretted it , bought it back about 3 years ago . I just love the look and wanted more power . The car is a full steel conversion with all m3 suspension and OE parts .
                    • LINUS
                      • 2422
                      Green mounts = 65.8 mm height
                      Measured from face to face, not including that little tab on the bottom for location. Also, that's a fresh motor mount that has never had engine weight compressing it, since the design looks like it will compress over time.
                      It's not how you handle the good times, but the faith you keep in the bad that defines you.
                      • ericzz
                        • 286
                        944 booster installed with 1/4 inch plates on both sides and all is well .
                        The 944 booster needs to be cut and rethreaded but is otherwose bolt in direct fit .
                        • Mike B.
                          • Jan 2006
                          • 987
                          Thanks for the update. It's good to get this infomation out to future swappers.
                          • ericzz
                            • 286
                            IT RUNS ! sounds sweet just a cat for now exhaust shop on monday . Boy I can not wait to drive it .
                            • 87-325ic
                              • Apr 2006
                              • 1198
                              sorry for the ressurection..
                              but, for the Porsche booster, i do want the early model right? and it doesnt matter b/w 924/944... is the vacuum res really needed? and i can use the stock MC! thats a plus..
                              now for the mounts, where is everyone getting these green ones from? any recommendations on a urethane mount?
