Motor is in but have issues !
Because it's easier to modify the 924/944 booster. It's the same thread pitch (clevis) as the E30 booster and it just needs to be shortened a bit. One quick swipe with a cut-off wheel and your done.Comment
are they the oem ones? and they just happen to be green? any part numbers for this stuff?
thanks for the help.. and sorry to hijack this thread.Comment
I got some black mounts which appear to be for an e28 m5, they are $13 each from fap99. They look the same as the green ones, and they worked in my s50 swap.
I just hope they're the same quality as OEM, because the last thing I want to see is this motor moving forward under hard braking.I got some black mounts which appear to be for an e28 m5, they are $13 each from fap99. They look the same as the green ones, and they worked in my s50 swap.
http://fap99.com/item.wws?mfr=MEYLE&...11175735%2Ejpg
How long have you had those?Comment
I've only been using them for about 100 miles, no issues, they feel pretty solid.
Compare the pics, they looked exactly the same except for color, and it was listed for the e28 m5.
They are made by MEYLE, who I believe is an OEM supplier, someone correct me if not.
Not 100% sure, but I think MEYLE is aftermarket part.
Now, someone, correct ME if I'm wrong. ;)Comment
