Does it even have one ? I am looking at my old motor and really am second guessing myself on this .I see no wiring ? and can not remember ever having the oil level light on ! 1989 m3 fyi
e30 m3 oil level guage ?
The level sender needed for the swap is specific for the E34 oil pan. If you just have a blank on the bottom of the oil pan, then you don't have the sending unit. The sending unit has a 3-pin connector.
If it's something that your interested in having, it's a pretty straight forward install.
Originally posted by ericzz View PostYes I have a check panel and I have 100 % m3 wiring body harnes in my car . My ? is I do not think that the m3 came with a level senso . there is a blank on my pan with no wires maybe this is my issue !
does your check panel have an "engine oil" light?
the m3's should have a oil level light. the wiring is different between the 87's and 89's, but they both go through the c101 connector.
jason
AFAIK, I was told that since you are on a THR WHAD, all you need is the sender for the pan, to wire a connector to the pigtails in the harness, then the body side of the C101 will take the signal to the check panel, but you need a non-M check panel to add the LED for the level, since that's not on a early build (like mine) factory check panel.
I'm doing the same thing, and that's what I came up with, but I'm not that far into my swap so I'm not sure if that's 100% correct yet.
It's not how you handle the good times, but the faith you keep in the bad that defines you.
So what's the question then? I thought you didn't have a sensor in your pan.
Also, the sensor is just a float, so pull it yourself & clean it with brake cleaner, or soak it in kerosene or diesel for a day - once you can make it "rattle" by shaking it like you're whacking off - your float/sensor is working.
Double check it with a ohm meter, it's a simple open/close loop.
Once you're good you can chase the problem elsewhere if it persists.
My s52 has a sensor since the e34 pan included one . My s14 has no sensor in it nor did it ever . I have the check panel with an oil level led that is now lit . The sesor is not a float as per my conversation with THR it works on a heating element and the cooling of the level is what determines the level in the pan . After checking and probing my wiring is aces !
Bizzare. I had mine out and I did what I told you, I had a full open/close loop and I could see the float through the caging.
Not saying you're not right - just that was my experience. I should check the wiring charts for more info, never did that. I'm sure it will show on a diagram.
Thanks for setting me straight - I'm probably wrong.
So what exactly was the problem & what was the solution?
It would benefit us if we all did a better job of posting our solutions after a problem arises, imagine how great when we search key words that not only would we find the problem like others had, but maybe what a solution is too.
Originally posted by LINUS View PostSo what exactly was the problem & what was the solution?
:woowoo:Originally posted by 325Projectzdon't listen to the diagram... listen to mr. swiss.
