I hate California smog laws
  • windnsea00
    • 158
    Originally posted by bostonbmw
    unplug one of your injectors and it will lean out the ratio of exhaust gases and you should pass. It will be running on 5 cycl the 6th will be acting as an air pump helping to dilute your exhaust gases to give the appearance that its running cleaner than it really is. Cheers Brian
    Very interesting, here's the report:
    I'm the potential buyer of this car so I want to get this thing to pass! I've given up once on my previous E30 but just some time and $ this should work.
    Past: 1991 330is; 1995 318ti; 1993 325is; 1997 318ti; 1989 332is; 1999 Z3 M Coupe
    • windnsea00
      • 158
      Originally posted by MR 325
      Even though you technically "have to" make the car Smog legal to sell it here, you really don't. The person buying it should know what's up with it. Shit dude, if you want an illegal Smog, let me know. :)
      Once the car is entered in the system, can you do a "special" smog?
      • mitch500
        • Jan 2006
        • 1092
        sell it in canada ive seen e30 m50's go between 7-13,000$ depending on the condition. plus only a few places here test for emissions. just my 2 cents.
        1988 e30 alpine white vert 5speed
        1987 e30 325 eta
        1983 e28 533
        2001 x5 4.4l
        1997 e36 M3 Alpine white 5speed
        1991 Jeep XJ I6 4.0
        • PiercedE30
          • Apr 2005
          • 4220
          Don't only OBDII cars have air pumps/air injection? WTF was that dude smoking when he said "missing"? And wtf is with him saying "missing - wiring to sensors," what sensors? Also, on the check light, just pull the wire that turns on the light on the dash (for the test).
          My 2.9L Build!
          • windnsea00
            • 158
            I was a bit confused on that too...not to mention the CEL wasn't on when I drove the car this past weekend.
            • BimmerToad
              • Sep 2004
              • 1537
              problem is once you've gone to the ref once, you need to pass smog with the ref, so shady shops aren't an option for the initial smog post swap (IIRC)
              San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
              • windnsea00
                • 158
                I think your right Todd...maybe if I pick this car up you can help me get it to pass :) How about some free details/beer/pizza in exchange ;)
                  • 37832
                  Originally posted by bdi_fc
                  Stock ECU for an S50?
                  What size injectors should I use?
                  And the MAF is the 3.0?
                  Yes, all stock S50 parts.
                  Classic BMW Specialists
                  Grover Beach, CA
                  www.BimmerHeads.com
                  • golde30
                    • 11464
                    why did u take it to a referree in the first place? i would just take off the plastic engine covers, and drive to any smog station and act like its all stock...
                    IG: @Baye30
                    • BimmerToad
                      • Sep 2004
                      • 1537
                      or a S52 shortblock :D jk
                      • windnsea00
                        • 158
                        I will see what I can do :)
                        • dark89e30
                          • 263
                          If you are using a s52 block (obd 2 engine) then the ref will register the engine as a obd 2 car. Just because you have a obd1 harness on the car doesn't mean you can smog the car as 1. They read the engine serial number and they know what it came out of. If it was legal to put on older fuel delivery than what came on the engine then I'd be running side draft carbs. If the block came with OBD II then that it what you have to have to make it legal. And at this point its a bad idea to try a magic smog because there is a good chance that they will check out the smog station that passes you, and thats if you get one to do it after your previous smog check. You're pretty much in a hole. Putting on a bunch or s50 parts is a waste of time/money.
                          • bdi_fc
                            • 273
                            There's no vin tag the guy can see. So he tested it as an S50.
                            There's no way for him to tell except for the fact he saw the OBDII manifold and airpump parts. That was my fault since I thought it was a bit more lenient.
                            As far as the check engine light goes, it works. The idiot didn't seem to accept the fact that it was a check engine light because it didn't say "Check Engine." He insisted I take apart the cluster and get a sharpee to label it.
                            E30 Wiki: e30dohc.com/wiki
                            • dark89e30
                              • 263
                              By law the serial number has to be cast into the block and by law he has to look at it. It doesn't matter if there is a vin tag or not. And he was probably having a shitty day about the check engine light thing, thats BS. Either way, he goes off of the cast-in serial number.
                              • Jean
                                • 18228
                                Man, sounds like you got an a-hole ref... a friend of mine just got his car ref'ed and it went smoothly..
