we r almost finished with the swap...'98 obd1 s52 into '89 3251...413 red label ecu, 24# injectors, 3.5" hfm, tms chip for mods+ ews and speed sensor delete...car hasn't been able to rev past 5k on the tach since we've started it, with the tms chip or the stock chip...could it be that he has a 325 dme instead of and m3, or will that not make a difference with the tuning??? need answers asap, so please ring in if u have any insight...thanks
my friend's car wont rev over 5 grand
INSTAGRAM: @UNDR8D_EMPIRE
Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Tags: None
Originally posted by e30polak View Postwe r almost finished with the swap...'98 obd1 s52 into '89 3251...413 red label ecu, 24# injectors, 3.5" hfm, tms chip for mods+ ews and speed sensor delete...car hasn't been able to rev past 5k on the tach since we've started it, with the tms chip or the stock chip...could it be that he has a 325 dme instead of and m3, or will that not make a difference with the tuning??? need answers asap, so please ring in if u have any insight...thanks
What does it sound like it is cutting the REV at 5k?
This is a weird problem, maybe fuel pressure?
The M3 and the 325 DMEs are interchange-able, as long as they are the same label, and the harnesses off of a vanos M/S50 should be the same (sans auto).
I would suspect either the DME or HFM. Try a known working one of each and see if it resolves the problem.
Does the speed sensor delete just eliminate the speed limiter, or is the speed sensor signal also incorporated in the engine tuning?San Diego BMW repair -> Jake @ www.littlecarshop.com Great guy :up:
speed sensor delete has no effect on the revs...it's not the hfm, tps, or any sensor...i guess we'll try a diff. dme...MATT WHERE R U ON THIS? I NEED SOME ADVICE FROM THE KINGCheck out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
r u saying that that's the problem?Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
thanks i'll try that...by the way totally unrelated, but wut size borbet's u runnin? ur car is pimpCheck out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
but if i have a speed sensor delete on the chip, won't it disregard the reading coming from the sensor? and i'm saying that it wont rev past 5k whether the car is sitting in neutral or driving...so when it's sitting, how does the speed sensor have any effect?Last edited by e30polak; 09-27-2007, 09:36 AM.Check out Undr8d Empire on Facebook: www.facebook.com/Undr8dEmpireLlc
not sure but I know that if its not plugged in or is broken than the car won't go over 5k. If its unplugged or deleted then how would the speedo register?///Alpinweiß II 24v 91' 318is, Alpinweiß III 99' 323i, 04' Yamaha R6 SE for sale, 00' VW GTi, 83' El Camino BURNED, 01' P71sold, 92' Miatasold
