my friend's car wont rev over 5 grand
  • FredK
    • 14759
    Did you hook up pin 14 on the C101?
    • e30polak
      • 6136
      wut wire is that and wut does it deal with? sorry i didn't do the electrical
      INSTAGRAM: @UNDR8D_EMPIRE
      • FredK
        • 14759
        Road speed signal.
        Now, the TMS chip is supposed to remove the DME's reliance on pin 14 for the road speed signal. Which makes it very odd that your friend's car stops at 5K. Does it cut the fuel off, or does it just die?
        • e30polak
          • 6136
          it sounds like the car is being governed at 5k, it doesn't die
          • e30polak
            • 6136
            i'm getting another dme tomorrow to see if that's the issue
            • e30polak
              • 6136
              it's not the dme...could it be the harmonic balancer???
              • DEV0 E30
                • Oct 2004
                • 8851
                Um, I don't see that possible.
                The only way that would be true is if it rev'd over 5k in neutral but not in gear. And you'd have much bigger problems, like a body clinging to the driveshaft preventing it from going anywhere.
                It's got to be electrical. Sounds like a speed sensor problem.
                Coding plug on the back of your cluster?
                • mazur
                  • Jan 2006
                  • 731
                  You never answered if the MPG guage works or not...:roll:
                  Why I ask is, if it doesn't, it means that the DME is not getting a speed signal from the cluster which is fed by the diff. speed sensor.
                  I had this problem with my car, only I was able to hit 6k usually. Changing speedo out solved my problem.
                  • equate975
                    • Jun 2004
                    • 3382
                    Man, I am surprised you guys have helped this fuck nut for as long as you have. He obviously has no idea what he is doing and I can't barely fucking understand what he is asking.
                    LEARN TO FUCKING TYPE for christ sake.
                    Rollin' with a Geistkuchen
                    • 2002maniac
                      • 4260
                      wut?
                      • SpecM
                        • Oct 2005
                        • 4531
                        Originally posted by 2002maniac
                        wut?
                        -Yea... what are YOU talking about?
                        1989 cirrisblau-metallic 325i
                        • aeryk7
                          • Oct 2005
                          • 616
                          Originally posted by asubimmer
                          not sure but I know that if its not plugged in or is broken than the car won't go over 5k. If its unplugged or deleted then how would the speedo register?
                          This is very wrong , atleast for BMW's . The speed sensor in the Diff will not effect the reving or top speed. I have done this on numerous chassis.
                          this does sound like a tuning issue though or maybe a wrong crank sensor/ reference sensor. Generally you can scan the Ecu to get an idea of where something is going wrong.
                          253rwhp
                          My Vids(OLD)
                          http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                          http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                          • asubimmer
                            • 6482
                            lol you are full of yourself. I know it at least effects the 24vers. I have heard of that from a ton of people who actually know what they are doing unlike most forum kiddies like yuorself. I even unplugged mine today to test it out and guess what?!?!?1 I was right...
                            • hendrixvodu
                              • Jan 2007
                              • 2514
                              325e :jk:
                              -His-
                              87 e30 325i
                              87 e24 m6
                              05 e83 x3
                              94 e32 740i 5spd
                              -Hers-
                              89 e30 325i
                              18 f48 x1
                              • mazur
                                • Jan 2006
                                • 731
                                It does affect it...I had that problem for a while till I figured it out. One of the people who pointed me to the problem was Stickley...you know, the BMW race engine builder.;)
