Started The Swap Tonight *w00t*
  • 94is
    • 90
    #31
    So the reason this car wasn't done a couple weeks ago, is due mainly to parts issues. First off, the M52 turned out to not only have a headgasket leak, but a slightly warped head, and 24 valves in need of replacing. That set us back just over a week. Also, the flywheel needed a new friction plate installed. I ended up having to mail it back to JB Racing for them to install one (way over in Florida). That should be back here on Friday. I believe we are planning on the car driving this weekend. *fingers crossed*
    I'm still waiting on some misc. valve cover hardware.
    25mm brake master installed.
    Ground Control Camber Plates
    Finally beginning to resemble a running vehicle.
    21.5# injectors
    Neil rigged up this baby.
    Ground Control coilovers with Eibach sways
    The starter is just chillin', waiting for the tranny to go in.
    '90 325i SterlingSilver/Black 5spd
    '94 325is #94 IP
    • FredK
      • 14761
      #32
      Whew, lotsa progress! Did you get the head redone?
      I'd use fuel injection hose for the fuel lines. Sure it's $5 a foot, but you should be able to do the supply lines and little hoses that feed the rail with around 5 feet of line. Cheap insurance.
      • matt
        • 3731
        #33
        It's not $5 a foot... it's $15 a meter! Gosh.
        Kim, don't you need a chip for this car? :mrgreen:
        • 94is
          • 90
          #34
          I bought 5/16" fuel line (they didn't have 1/4").
          And yes, I had the machine shop resurface the head (not enough to warrant a thicker hg), and they replaced all of the valves, valve guides, and seals. That was an expense that I was not expecting. I felt bad for the woman I'm doing the work for. :(
          The chip from AA should be here tomorrow or Friday. :D
          '94 325is #94 IP
          • matt
            • 3731
            #35
            I'm sorry.
            • Speedjunkiejp
              • Jan 2008
              • 69
              #36
              great progress! i cant wait to start on mine in a few weeks
                • 37829
                #37
                Looks good Kim. Is the motor being transported in Neil's iX in that pic? lol
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • 94is
                  • 90
                  #38
                  It is. I drove through In N Out, and nobody even noticed. :(
                  Btw, we aren't running any shims or anything, and everything fits. Is that normal? :?
                  '94 325is #94 IP
                  • JPStrniste
                    • 146
                    #39
                    i didn't need any shims with my swap either
                    • FredK
                      • 14761
                      #40
                      I used 5/16" fuel injection hose that I bought at Advance Auto.
                      I originally bought 5/16 regular fuel hose, but I didn't use it. My only use for it now is with a screwdriver inserted into it in order to bend the heater core pipes. :razz:
                      • JPStrniste
                        • 146
                        #41
                        this works too. (I've seen it done!!)
                        • gobuffs
                          • Dec 2004
                          • 513
                          #42
                          For some reason I thought you were doing a Euro swap.
                            • 37829
                            #43
                            Haha, nice.
                            I didn't need any shims for motor clearance, I have to add a small one to clear the ebay headers over the subframe.
                            Grover Beach, CA
                            www.BimmerHeads.com
                            • 94is
                              • 90
                              #44
                              Yeah, mine is Fuel Injection hose too. You can see it printed on the hose in a couple of the above pics.
                              I am. This e30 isn't mine. I'm just getting paid to do the work. Once I get paid for it, I can pay Alex for my euro motor, which will be going into my e36.
                              '94 325is #94 IP
                              • FredK
                                • 14761
                                #45
                                ah, I could have sworn it said "not for fuel injection systems made in usa by gates"
