3.46 lsd
  • Ali//325i
    • Jul 2005
    • 270
    3.46 lsd
    3.46 lsd from an 1986 735i fit?
    I am looking to purchase this one, but i need to know if it will fit, I will be using the zf tranny and the 97 m3 drivetrain with the e30 CSB.
  • DaN
    • 1265
    The rear cover won't work, but the top mounting holes on the case look ok.
    May need to just swap output flanges and the cover.
    Need more pics, or someone who knows for sure.
    • FredK
      • 14762
      Yes, an E23 diff will definitely work.
      As DaN said, you'll have to swap output flanges and the rear cover. The E23, E24, and E28 all had slightly larger bolt circle diameter output flanges.
      • GoKart
        • Jan 2008
        • 136
        How hard is it to swap the output flanges?
        • SchnellerVert
          • Sep 2005
          • 3948
          Easy.
          • GoKart
            • Jan 2008
            • 136
            Originally posted by SchnellerVert
            Easy.
            Details?
            • gazellebeigem3
              • Jun 2005
              • 3712
              They slide right out with a flathead/prybar and snap back in.
              • GoKart
                • Jan 2008
                • 136
                Any seals or gaskets required?
                • Mike B.
                  • Jan 2006
                  • 987
                  You can replace the output shaft seals when you change the output shafts, it is cheap insurance. You will also need a new gasket for the E30 cover.
                  • e30polak
                    • 6136
                    i kinda wish i went with 3.46 instead of my 3.25, if u r using the e36 ZF u r going to love the length and torque in the gears :pimp:
                    INSTAGRAM: @UNDR8D_EMPIRE
                    • BlackE30
                      • Sep 2004
                      • 605
                      Sorry to highjack your thread but would a 3.46 work well with a getrag 260 and a s52 or would a 3.25 work better. I have a 3.73 now and it could def use some longer gears.
                      Jeff
                      • SchnellerVert
                        • Sep 2005
                        • 3948
                        Torque and HP of a S52 will have no issue.
                        • Garageaholic
                          Freestyle Fabricator
                          • Dec 2005
                          • 5204
                          The hole pattern looks good, but I can't see the other 2 holes. Post more pictures at different angles.
                          Swap the rear cover and probably the output of half shafts.
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          Instagram.com/garageaholic
                          Youtube.com/garageaholic
                          • aeryk7
                            • Oct 2005
                            • 616
                            On real oem it says the e32 735i auto or manual comes with a (3.64 ) not a 3.46
                            http://www.realoem.com/bmw/partgrp.d...59&hg=33&fg=05
                            253rwhp
                            My Vids(OLD)
                            http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
                            http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
                            • Funkmasta
                              • May 2004
                              • 7185
                              The 735 that he is dealing with is an E23.
                              E23 diffs DO fit into 6 cylinder E30s except the diff from the 745.
                              Using a prybar as a lever (between the case and the flange), and the heel of your palm as the hammer, 'pop' out the output flanges. The new ones pop in more easily.
                              Swap out the rear cover for an E30 cover. Now is the time to switch out that bushing.
                              Joe Funk -- Portland Oregon
                              That Guy.
                              03 X5. 3 liter obviously.
