S50 started, but a couple issues.
  • golde30
    • 11464
    ok. so the motor started for the first time 2nite, and on the first try.
    HOWEVER, it only started twice, and now when i go to start it it just clunks loudly, and the starter doesnt crank, like its jammed or something??
    second, is my fuel pump supposed to prime when the key is turned to start, but not cranked? i busted out the circuit tester, and the pump gets NO power in the fuse box or relay when i have the key turned to start, and as soon as i crank it they both get power and fuel DOES get to the motor. im running a silver label 413 w/ Matt's EWS delete chip if that matters. i know for sure with the m20 the pump DID prime with the key at start.
    thanks for any info. im really concerned about the loud clunk, and lack of cranking.
    IG: @Baye30
  • Jean
    • 18228
    Dude! I hope it's something simple man!
    • gregslow318i
      • Sep 2007
      • 1918
      can you turn the motor over by hand ie( put it in gear and push the car backwards) rock to car to un-jam the started
      also what is you battery voltage...dead battery?
      looking for a e30m50 swap harness adapter pm me $150 shipped
      email nitroman12@gmail.com
      • 1990m3
        • 1180
        my fuel pump primes for about 3 seconds when the motor is cold. When it's not cold it doesn't seem to prime...but it starts everytime so I always assumed it was working properly. I have a TMS EWS delete chip with a silver 413 ECU and s50.
        Can't help you with the flywheel, I'm using all e36 parts down there.
        • etxxz
          • Feb 2006
          • 2085
          the pump is supposed to prime for about 2-3seconds like 1990guy states
          i'm not understanding the starter problem though. if its stuck see if by turning it manually by the crank lets it loose. hope you got a new starter though <- some major work on this engine for everything that must come out first!
          No more e30s for me.
          88 black BMW OBDII 332is dedicated track [sold]
          88 BMW OBDII bronzit 332is [RIP 03/08]
          91 BMW 325i [sold]
          86 Corolla 'Ae86' HB 20v trd [sold]
          http://youtube.com/watch?v=pTj7Hn9v5Rs
          • PiercedE30
            • Apr 2005
            • 4220
            Sounds like the same problem I had when I first went to start it. Make sure that the starter is straight and not hitting the metal plate between the motor and tranny.
            My 2.9L Build!
            • JPStrniste
              • 146
              what is the name of that metal plate between the motor and bell housing? or do you have a part number for it? i damaged mine when i took the auto tranny off the motor.
              I've checked a couple different sites, ie Realoem.com, and rmeuropean.com, and couldn't find it.
              thanks
              • golde30
                • 11464
                well it started a couple times, so i dont think its hitting the metal plate between the tranny and motor. the battery is new, but it mite be weak. i am running an e36 flywheel/clutch/starter with a getrag260.
                no advice for the fuel pump priming? what controls this function, the ECU?
                IG: @Baye30
                • FredK
                  • 14762
                  Covering plate 11141734019
                  • matt
                    • 3732
                    ECU, fuel pump relay, fuel pump fuse, fuel pump wiring, fuel pump itself...
                    How long did it run for?
                    • golde30
                      • 11464
                      ran for like 5 seconds before i shut it off. there was only like 1 gallon of coolant in the motor, we were just testing the wiring. it must be an ECU issue then, b/c the relay gets no power until the motor is cranked...the fuel pump is pretty new, replaced it earlier this year.
                      could this be an issue with the EWS ECU?
                      IG: @Baye30
                      • etxxz
                        • Feb 2006
                        • 2085
                        i run an obdII car with ewsII and 2 keys. The fuel pump will prime for 2-3secs when i turn the e30 key to the "Run" position even if i don't have the e36 (chip) key inserted. so its not an ews thing in this sense
                        what i do recognize as an ews thing is the starter running--> engine cranks but doesnt fire, then the starter changes noise like its not touching the flywheel just spinning freely and then finally clunks as if it were stuck....That WILL happen w/o the ews disabled (key not inserted/turned in my case) Sounds familiar?
                        ews cuts off what? i believe its fuel, spark and starer (only if wired through the ews module) so if your car runs it means you got them all and the problem is elsewhere, maybe a huge vacuum leak, like if the round plug/hose behind the intake mani werent connected. happened to me..
                        ..just commenting maybe something here is helpful
                        91 BMW 325i [sold]
                        • viali8
                          • Nov 2005
                          • 673
                          FYI: My car suddenly would not start about month ago. After many hours of reading (some misinformation) i finally realized that when the key is in the start position my fuel pump was not getting the 12v. I also read that my fuel pump is supposed to prime the system before the car is started. This was not true in my case. I only got 12v at the pump when i attempted to start the motor. I replaced the fuel pump and it fired right up. Hope this helps. Best of luck
                          • mitch500
                            • Jan 2006
                            • 1092
                            hmm i do recall now on my friends m50 the hard hose that looks like a turkey neck from the icv behind the intake was dissconected. when we tried to fire it, it ran like shit and clucked. reconected it and she ran great. just a suggestion
                            1988 e30 alpine white vert 5speed
                            1987 e30 325 eta
                            1983 e28 533
                            2001 x5 4.4l
                            1997 e36 M3 Alpine white 5speed
                            1991 Jeep XJ I6 4.0
                            • matt
                              • 3732
                              It's not an EWS thing, I assure you. What is your CEL doing while all this is happening? Be specific.
