S50 started, but a couple issues.
  • golde30
    • 11464
    ok, i tried to turn the crank, and it was stuck(didnt wanna try to hard). so i took apart the intake mani, and removed the starter, but the crank is still stuck. something is in the way, i just dont know what it is... has any1 else ran the e36 clultch/flywheel setup with a getrag 260??
    its no the starter keeping me from cranking basically...its something else. im racking my brain here, its getting frustrating.
    IG: @Baye30
    • PiercedE30
      • Apr 2005
      • 4220
      The car isn't in gear right?
      My 2.9L Build!
      • gazellebeigem3
        • Jun 2005
        • 3712
        Im using e36 clutch/flywheel and starter with the 260, no issues here.
        Is the shift linkage attached and not in gear?
        • golde30
          • 11464
          car is not in gear, but get this...
          i just bled the clutch slave, and now when my friend pushes in the clutch pedal(tranny is in neutral), i can turn the crank, whereas before i couldnt turn the crank AT ALL... what does this mean??
          if i let out the clutch pedal, with the tranny still in neutral, the crank is totally stuck again.
          IG: @Baye30
          • surebimmer
            • Jan 2004
            • 978
            So your sure that the trans is in neutral when the clutch pedal is out, you can turn the drive shaft by hand if your wheels are off the ground. Sounds to me like the trans is stuck in gear.
            • golde30
              • 11464
              its not in gear. i can turn the output shaft with the wheels off the ground easily.
              i am pulling the tranny off in the car, it can be done, its just a bitch. i guess i will find out whats going on with the clutch when the tranny is out of the car.
              IG: @Baye30
              • surebimmer
                • Jan 2004
                • 978
                Sounds like you have a case of the same problem Jason (C3) had when he tried to fire up his car.
                • Justin B
                  Sikky Nar Nar
                  • Mar 2005
                  • 4273
                  Damn dude, just updated myself in this thread. Good luck finding out what the clutch shit is doing to lock it all up. That's weird.
                  • golde30
                    • 11464
                    oh man. one thing after another. its definately a tranny related problem. we cannot get the tranny to break loose from the block. its really stuck on there. we are prying the hell out of it where it seperated like 3mm. man, its really really on there. calling it a nite 1am. will be back at it around 9am.
                    IG: @Baye30
                    • golde30
                      • 11464
                      the damn tranny will not come out. it is stuck on the motor. i dont know what to do, what a bitch.
                      IG: @Baye30
                      • e30serg
                        • Dec 2006
                        • 562
                        Are you sure you got all the bolts out? I just took the tranny off my s52 this weekend and noticed a little bolt right behind the back header. The little bolt holds the plate that gets sandwiched between the block and the bellhousing. It made the plate twist and jam on the dowels that come off the block.
                        Otherwise, the tranny came out smoothly though.
                        • Jean
                          • 18228
                          Hope you get it out w/o pulling the motor ! But, if you end up pulling the motor with the tranny, I bet you'll be able to put it back in with your eyes closed ;)
                          • Justin B
                            Sikky Nar Nar
                            • Mar 2005
                            • 4273
                            Hey Cary, that sucks. Are you going to be working on it tomorrow? I have school till noon, then I'm going to be heading to Concord probably in the early afternoon right after class...I may be down to come over and look confused with ya if you want any more help.
                            How far is it sliding off? Call me, or get on AIM later and lemme know.
                            Good luck man.
                            • FredK
                              • 14759
                              Yeah sometimes there's a slight misalignment that makes it tough to pull the trans out. Just the right combo of supporting the weight of the trans with a jack so it's not being supported by the input shaft and swearing will make it come out.
                              • golde30
                                • 11464
                                well, had to break apart the entire bell housing to get to the pressure plate bolts off, then the entire tranny came off with the pressure plate and clutch disk stuck to the tranny. the clutch was seized somehow...we dont know it happened, and the clutch is really stuck to the tranny, we are gonna have to hammer off the disk.
                                the tranny is toast of course, i will post up some pics of the tranny is a lil bit. dont know what went wrong. luckily i had an extra getrag260 sitting around that i can use.
                                some1 tell me what went wrong?? why did the clutch disk sieze up on the tranny imput shaft??
                                IG: @Baye30
