Wiring up EWS
  • MarkD
    • Sep 2004
    • 488
    Originally posted by gobuffs
    This works....I posted it. :-) I have no EWS issues on my S50 B32 swap.
    I heard a rumor that D'Sylva MIGHT be able to bypass EWS on the S50B32.
    I just saw this 2 year old post. It was not a rumor, I had that figured out a few years ago.
    URL: www.dsylva-tech.ca
    • IanS_in_Oz
      • Jan 2010
      • 75
      I'm running EWS II on my '84 E30 M52 Euro swap. Got the pin-outs from Ian Haynes, and it fired first turn...
      BumbleE30 M52 2.8i
      • davebmx
        • Aug 2013
        • 1
        Sorry to dig up an old thread and also hijack but i was wondering if anyone could point out how the ews modules pins are numbered as i dont have the connector. this is for an m44 from a z3 engine but it definately has ews ii
        regards
        Dave:D
        • dsobering47
          • Oct 2007
          • 697
          why do people still want EWS? For these cars, its such a simple system that you could jump the signal wires between the module and bypass the system completely....making it completely worthless.
          If you want to have fun with wiring and have an anti-theft system, why not wire in a hidden fuel pump kill switch? There are many other easier approaches than using an outdated antitheft system.
          • 328ijunkie
            • May 2007
            • 3961
            Don't think you understand ews2 and above. You can't hot wire around it. Yes you may be able to get the starter to fire but the ecu won't ever fire fuel/spark.
            Check Us out on Facebook
            Full Product Line Tuning
            • dsobering47
              • Oct 2007
              • 697
              Lol no I've bypassed ews2 before... Not that hard
              • 328ijunkie
                • May 2007
                • 3961
                With a ECU flash or emulator yes.
