Ok lets start with what I have.
I have a 91 318is and a 95 525i M50 from a automatic e34. I got everything installed but no spark.
When I hook up the battery all the lights along the bottom of the cluster come on.
I used the AKG adapter to hook everything up.
Here is some photos of what I have questions about.
This is the harness that connects into the M42 ECU. I dont have the small plug on the M50 harness so where do I splice these 2 wires in and what do they do??
This plug here is for the MAF but I have one under the intake thats not plugged in to anything and I cant really see where it goes or find out what its for since I wasnt the only one taking the motor out.
This is connected in with the harness. Once again I dont know if I need to connect anything to it or now.
Does everything here look correct?
ok now when we took the m50 out the starter was still connected to the block with all the wires. There was 2 big wires that are + correct?
and then there was 2 smaller wires.
one connects on one side of the starter and one connects on the other side of the starter.
When I got the M20 starter since I used the single mass M20 flywheels.
There was a prong for the 2 bigger wires and one prong for one of the smaller wires. but no prong for the other smaller wire. So can I just put a bigger end on it and connect it with the other smaller wire??
This is the way she sits with the motor...
I JUST WANT TO DRIVE THE FUCKIN THING!!!! :hitler:
Still waiting on my cage to come then I can make brackets for my seats.
