NO SPARK, Need some help please.
  • loonibab325i
    • Dec 2005
    • 770
    Originally posted by btec116
    You're runnign an M20flywheel? Ive heard the difference in weight is enough to cause the idle problems. Light flywleel motors tend to always hunt around, Since the system is alot lighter the ICV over-corrects and ends up floating around the ideal idle. It seems plausible depending on how the controller works. However, this is somethig I have heard from several people but not tried yet (anyone care to comment?). I am still yet to get my exhaust on (from headers-back); That also makes for a rough idle!!!
    You know, this kind of makes sense. I am guessing that's the reason why people get LTW flywheel chip options too?
    -Abe.
    s52 0-150mph & more http://www.youtube.com/loonibab325i
    • e30this
      • 3580
      well what the fuck. I will just wait till its all together.
      If it doesnt work, then I dont know.
      • EtaSport
        • 2853
        I have an m20 flywheel in mine.. you know they weigh like 20 lbs right? Not light in any sense of the way, and definitely not going to make your idle go up and down. It is very similar in weight to the s50 flywheel.
        Make sure you have a sufficient ground connection on the engine first off. Second, make sure you have the HFM installed the right way. Check and clean your ICV, mine would bounce after driving and coming up to a stop, cleaning the ICV fixed this. Last, what did you do about your charcoal canister and evap solenoid? If that gets blocked, it will do the exact thing you are describing.
        The two wire plug is for AC idle bump. M50 has it built into the harness on the x20.
        btw, Im suprised the AKG harness worked out for you.
        Old and improved:
        • e30this
          • 3580
          Why you suprised the adapter worked??
          • loonibab325i
            • Dec 2005
            • 770
            Yeah, i would also like to know why you are surprised?
            -Abe.
            • btec116
              • Jun 2007
              • 131
              Dont know what you're packing but my M20 flywheel weighs just over 6kg -thats about 13 pound in your native tongue;)
              Its the only good reason to use it.
              • EtaSport
                • 2853
                perhaps you are thinking of a 323 wheel... a single mass 325i flywheel is about 20lbs.
                Many people have tried AKG adapters and wiring diagrams.. many have failed. There is documentation, most noteably from MR 325 the site admin.
                Old and improved:
                • btec116
                  • Jun 2007
                  • 131
                  Ahh, apologies, right you are. Yes I have an early 323 flywheel.
                  Did any M20 325's have the smaller flywheel? I thought they did.
                  • EtaSport
                    • 2853
                    Supposedly that is the smaller flywheel. Dual mass weighs about 28 lbs. Single mass is really easy to lighten though some people have got them down to 15-13 lbs.
                    my idle is starting to bounce around again for some reason. only while i am coming to stop. once the car stops and sits it is fine.
                    Old and improved:
                    • Charlie
                      kid tested, administrator approved
                      • 6686
                      Your dead starter, did it just simply do nothing at all?
                      Trying to diagnose mine right now. Get power to everything, fuel pump whirrs to life, go to crank..and nothing at all. Everything appears to be wired correctly, all fuses look good, battery is brand new. Same deal, M20 starter, m20 lightweight fly, G260.
                      -Charlie
                      Swing wild, brake later, don't apologize.
                      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
                      FYYFF
                      • e30this
                        • 3580
                        I dont remember what the problem was. I think it had a lot to do with the ECU not being grounded. The red wire from the relays not being hooked up and not having enough juice.
