"Fan delete mod"
  • clavinZERO
    Hella sick E30
    • Mar 2004
    • 2027
    #31
    I suspect both of the relays are the same for the high/low speed. I will check later though; the wires coming to the fan from the relay box are equal in gauge it seems. My new fan is only a 10 amp draw anyhow. I will definitely take another look today before I tear into it.
    "BMW Style 32 Poster-Child"
    HTTP://WWW.CLAVINZERO.COM/e30-5-lug
    **(My Guide to E36 M3/Z3 1.9L 5-lug Swap)
      • 34835
      #32
      The relays are, but the wiring and fuses might not be. I think the low speed fuse is 8.5 amps, not a big deal to swap out for a 10a or 15a, but I'd rather use the high speed circuit rather than worry about burning up some wiring and overheating my car. :)
      • clavinZERO
        Hella sick E30
        • Mar 2004
        • 2027
        #33
        If the wires are the same gauge, which I am almost positive they are, I will then just up the fuse rating like you said. I'll post pics and stuff eventually.
        • Mike
          • 932
          #34
          Good info to know, so I am digging this old thread back up, sorry guys!
          Supatek -noun - your basic know it all
          • guibo09
            • Dec 2008
            • 834
            #35
            so if i understand this thread correctly, i can simply remove my mechanical fan, replace the thermostat and pour in some water wetter and my car will have sufficient cooling in hot traffic with the AC on?
            90 E30 325i
            • MDryVur
              • 395
              #36
              i went ahead and bought an electric thermostat so i don't go through fuses like a bag of skittles.
              i couldnt find the exact one i purchased but this is very similar. This one is from JEGS.
              you guys should check it out... its a good upgrade.
              http://www.jegs.com/i/Painless/764/30112/10002/-1
                • 34835
                #37
                no, you need the lower temp thermoswitch as well, or your fan won't turn on until 90-99c.
                and you also need to verify that your aux fan actually works..
                • guibo09
                  • Dec 2008
                  • 834
                  #38
                  yeah sorry, by thermostat, i meant the switch for the aux fan.
                  yes my aux fan should work correctly, i just purchased a rust free one with a condensor since my fan was seized and the condensor leaked.
                  what i wanted to confirm was that hot summer traffic days with AC would be okay. i know most guys who delete the mechanical fan dont run AC anymore.
                  90 E30 325i
                    • 34835
                    #39
                    you can bypass the low speed on the thermoswitch so it turns on the high speed when it reaches the 80c threshold (just change the wires on the connector so it grounds the high speed for both posts). the AC will still turn on the low speed unless it starts to get warmer, then the high speed would kick in. that would work.
                    • slo325i
                      • 417
                      #40
                      Why are people hatin up on clutch fans???
                      Unless clearance is the issue, clutch fans are awesome. I've seen 500-600 2jz's and rb25's still running clutch fans w/ no problems. Why get rid of what the BMW engineers spent millions researching for??
                      Just my 2cents
                      '89 325i - Totaled... good bye my love...
                      '87 327i budget stroker - SOLD!!!
                      '92 240sx - ca18det powered drift toy - SOLD!!!
                      '89 325i - coupe - NEW daily
                      '96 Audi A6 Quattro- Grocery getter/baby hauler
                      '99 Busa - weekend wheelie monster
                      • guibo09
                        • Dec 2008
                        • 834
                        #41
                        Just my 2cents
                        weight and engine drag reduction?
                        90 E30 325i
                          • 34835
                          #42
                          Just my 2cents
                          because it makes working on the engine easier.
                          • guibo09
                            • Dec 2008
                            • 834
                            #43
                            do you keep the fan shroud?
                            90 E30 325i
                            • lifeiskaos
                              • 1709
                              #44
                              no
                              • slo325i
                                • 417
                                #45
                                Point taken. But the whole "less drag on engine" doesn't really apply to our motors.
