Transmission noise
  • hoveringuy
    • Dec 2005
    • 2735
    Transmission noise
    I have a moderately lightened flywheel with my M50-260 engine/tranny combo and I've got the famous diesel clatter at idle with the clutch out.
    It's disconcerting but I guess it's a known issue.
    Anybody have any luck quieting it down with heavier weight transmission oil?
  • 1990m3
    • 1180
    It's the nature of a ltw flywheel. My m3 does it, my swapped car does it and they're both using the same aluminum flywheel. Turn the radio louder...
    Seriously though, my m3 has had a ltw flywheel for at least 5 years and 20k miles, many of which were track miles. No side effects except for better acceleration
    • EtaSport
      • 2853
      Did you swap in an m20 pilot bearing?
      Old and improved:
      • hoveringuy
        • Dec 2005
        • 2735
        Yep. I remember that specifically. New T/O bearing, too.
        Seriously, my car sounds like a diesel after it gets really warm and I pull up to a light. Only after it's been driven for awhile and the transmission is warm.
        That's why I'm wondering if thicker oil would help.
        • PiercedE30
          • Apr 2005
          • 4220
          Mine sounds the same. I've got a 10 lb flywheel and a 6 puck sprung clutch.
          My 2.9L Build!
