Treehouse Racing Brake Booster
  • FredK
    • 14763
    :rofl:
    • Mr.SWISS
      • Nov 2005
      • 1251
      Dos guyz es loco.
      Originally posted by 325Projectz
      don't listen to the diagram... listen to mr. swiss.
      :nice:
      • E30Driv3R
        • May 2004
        • 1169
        Originally posted by Charlie
        175 from treehouse, with all the mod work done and a warranty, you can keep your existing master cylinder and resevoir.
        That's a no brainer.
        -Charlie
        Thats is what i was thinking.
        Dan Zickel
        1995 M3, 1991 318iS, 1987 325iS
        • grib
          • Oct 2006
          • 151
          I threaded the booster with a die, then ground off the threads, then die again.
          Wish THR had been doing their boosters then! If I could do it all over, I think I would go "iX booster" with the 25mm MC. Go used on the booster, new on the MC. They really aren't that much.
          1987 325i Cabrio - SOLD
          2014 Chevy Volt
          2007 FJ Cruiser
          • justin_l_
            • Jun 2007
            • 1079
            I just ordered my booster 2 weeks ago from treehouse and it was def $215 shipped.
            • btec116
              • Jun 2007
              • 131
              Originally posted by FredK
              u go gurl!
              No but really, the thought of making a larger hole in the clevis crossed my mind, then I began to overanalyze the situation. I thought, hey, maybe the clevis was designed to provide sufficient safety margins of axial strength only with a 10 mm hole.
              Clevis is in Compression! I dont see much wrong with that. Unless you like to pull on your brake pedal alot...
              Well anyway, thats what I did too (not the pulling). I'll make a post when it snaps;)
              • FredK
                • 14763
                Axial compressive forces?
                • Am pM HooDluM
                  • Aug 2007
                  • 72
                  Just do the 735 MC and Booster.
                  Mikey
                  -= Epitom3 =-
                  • matt
                    • 3732
                    Is that like angular compression?
                    • madjurgen
                      • May 2005
                      • 1203
                      He's right, whats the problem with what he said?
                      As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
                      You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
                      • matt
                        • 3732
                        Axial (along an axis) forces can be tension or compression.
                        • madjurgen
                          • May 2005
                          • 1203
                          Uh huh. And?
                          Oh because he corrected Fred, when Fred didnt specify?
                          • e30serg
                            • Dec 2006
                            • 562
                            Anyone know what kind of booster they are using? How is the brake feel and amount of boost affected? Is it easier to brake? Harder?
                            • iJowge
                              • May 2008
                              • 8
                              i have a tree house booster, didn't feel like looking for one and it's convienant. comes with a warranty. works good.
                              • 1fastcosmo
                                • Apr 2008
                                • 139
                                ill second that.
