Originally posted by highoutput
View Post
The comprehensive DOHC engine swap thread.
This is a sticky topic.
Originally posted by Matt-B View Postits also been covered 50 times a "EURO" 323i TO bearing, is the same as a 325i
i think i might have both at my friends place and could snap a pic for comparison's sake.IG: deniso_nsi Leave me feedback here
Originally posted by dude8383 View Posthate to call ya out on it but they're different. i can't for the life of me find the pic of the two sitting next to each other but the 323i TOB is taller than the 325i one.
Part 21517521471 (CLUTCH RELEASE BEARING) was found on the following E30 vehicles:
E30 323i Coupe, M20, Europe, MANUAL (1171) : Clutch
E30 323i Coupe, M20, Europe, RHD, MANUAL (1172) : Clutch
E30 323i Sedan, M20, Europe, MANUAL (1471) : Clutch
E30 323i Sedan, M20, Europe, RHD, MANUAL (1472) : Clutch
E30 325i Coupe, M20, USA, MANUAL (1113) : Clutch
E30 325i Sedan, M20, USA, MANUAL (1413) : Clutch
E30 325i Convertible, M20, USA, MANUAL (BB13) : Clutch
I'll grab part numbers for ya later tonight as well as pics for comparison. I had both of them sitting side by side when I did my 323i flywheel conversion on my m42 and they are different.
The 323i tob was aluminum while the 325i tob has some plastic here and there.IG: deniso_nsi Leave me feedback here
Originally posted by dude8383 View Posthttp://www.realoem.com/bmw/showparts...21&fg=05&hl=60
That part number is from an e21 323i equipped with an M20.
03 CLUTCH RELEASE BEARING 03/1984 21511204525 $113.18
03 CLUTCH RELEASE BEARING 21517521471 $75.34
http://www.m42club.com/forums/showpo...5&postcount=22 ;)
It was a mix-up on my part because thats the TOB I needed to use when converting the flywheel to a single mass on my M42.
You can go and pat yourself on the back now buddy.IG: deniso_nsi Leave me feedback here
Originally posted by Ryan Stewart View PostAaron my understanding is the master cylinder doesnt HAVE to be changed its just a nice upgrade while you are in there. The booster only has to be changed to make room for the rather large plenum.
i heard you can use the stock booster as long as you move it over to the right just a bit...
mtech 2 325ic
http://www.r3vlimited.com/board/pict...pictureid=7968
check out my donut vid
http://www.youtube.com/watch?v=Tw0paUP1FEQ
i have a 1988 e30 325ic, i also have a wrecked 95 m3 that im using the motor out of. the parts i know i need to buy are:
e34 525i oil pan, dipstick tube, dipstick, oil pich up tube.
e34 throttle cable
e36 engine mount arms
e28 535i or m5 engine mounts.
ix booster
since my m3 came with the original 413 grey lable i need to buy a 413 red lable.
i was told i can use my stock booster if i move it over a bit, is this true?
also can i use my 95 m3 driveline and diff? if so what will i benefit? thanks!
-moe
mtech 2 325ic
Originally posted by mohamadr89 View Posti have a 1988 e30 325ic, i also have a wrecked 95 m3 that im using the motor out of. the parts i know i need to buy are:
e34 throttle cable
ix booster
-moe
24V M50, M3 cams, Turner Tune, full exhaust, ect....
Originally posted by A_Whelan View PostQuick question, how often should the timing chained be replaced?
I think you should more check and replace as needed, tensioner, sprockets, and guides, never heard of a chain breaking
im so mad because i called the wrecking yard and they want about $900 for...
the throttle cable, oil pick up tube, dip stick, motor mounts, oil pan, ix booster, 413 red lable dmw, intake boot and maf sensor. i know its a lot of stuff for a good price but i still wasnt expecting to pay all this!!
mtech 2 325ic
