The comprehensive DOHC engine swap thread.
This is a sticky topic.
Okay, so I'm getting an S50 and Getrag 260 for my E30 soon. I need to pick up a flywheel, clutch, and pressure plate.
What motor should I use the flywheel, clutch, pp, etc. from? S50 or M20 starter?
Basically configure my engine-transmission connection, I'm confused and want to be sure I'm 100% right before I do anything in terms of parts purchases.Comment
Hey guys, Im in the middle of wiring up my auto>5speed 24v swap. On my 91 325is there are 2 connections that go from the interior to the m20 harness through the glovebox. One connection is green/black and the other is black/red, black/violet. Since Im doing an M52 swap, I need to know where these wires would connect to the m50tu harness. I know that the green/black wire is for the automatic neutral safety switch. I do not know what the black/red, black/violet wires are for.
What do I need to splice to what? Please help! Im finally almost done with my swap!
^M52B28^Comment
So I have an 86 325ES with an M50. Ix booster, not sure which res, but the install was a total hack. Installing a 2002 res remotely - is there any better solution?
Secondly, I have an 89 coolant res, but there is no mounting stud on the fender. How are you supposed to mount it on early cars with no stud?Comment
Most people use the 2002 res with that setup.So I have an 86 325ES with an M50. Ix booster, not sure which res, but the install was a total hack. Installing a 2002 res remotely - is there any better solution?
You can make a stud there to hold it or you can do a M42 rad and eliminate it all together.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
I did the majority of my harness wiring tonight (NV M50 into 89 E30) and I hooked up 13 wires. I made my own chart with colors, pin numbers, page numbers on the EMTs and all. I cross referenced this with AKG and matched them up. I was unsure about one thing. Oil Temp pin 19 on car side and X6031 pin 10 on engine side. What are these and how do I wire it?Comment
I think this is only present on Euro engines (engine harness side) and E30 M3 (car side). They have an oil temp gauge in place of the "fun-o-meter" fuel economy meter on your average E30.I did the majority of my harness wiring tonight (NV M50 into 89 E30) and I hooked up 13 wires. I made my own chart with colors, pin numbers, page numbers on the EMTs and all. I cross referenced this with AKG and matched them up. I was unsure about one thing. Oil Temp pin 19 on car side and X6031 pin 10 on engine side. What are these and how do I wire it?sigpic
Bodykit courtesy of BMW M GmbH.Comment
Did a 2002 res for the brake booster........ Turned out really clean, love it!
As for coolant, ended up just fabricating an aluminum reservoir..... Mounted in tray behind passenger strut tower. Looks pretty trick ;)Comment
