can i use my stock trans with my M50 swap?
  • alpinweiB
    • 287
    and dont tell me to search because i already have and i cant find an exact clear answer.
    i have an '87 325is and i assume the stock transmission is a Getrag 260 but im not 100% clear on that either.
    i've read that it will bolt up to the M50 and that i can use the stock transmission mounts and crossmember.
    is this true?
    if not, what do i need?
    obviously i can use the transmission that comes off of the M50 but i dont have one and i dont want to go get one if i dont have to
    what exactly is sigworthy
  • Ray McCooney
    • Jun 2006
    • 1088
    is this true?
    • Charlie
      kid tested, administrator approved
      • 6686
      Dude, really, search.
      Yes, it bolts to the motor, yes, you can use stock e30 mounts if you get a custom transmission brace, conversely you can use a combination of different mounts if you want to retain the stock brace. Again, hit "search", these aren't new things.
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
      • BDSax
        Junkyard King
        • Mar 2006
        • 3594
        did not work for me
        • Charlie
          • 6686
          Originally posted by BDSax
          did not work for me
          Okay. It's been done a number of times. Getting a custom brace works better.
          -Charlie
          FYYFF
          • hoveringuy
            • Dec 2005
            • 2753
            I used Doug's bracket, makes it plug and play.
            I like my 260 because I'm keeping all the gear ratios and the "feel" that I'm used to but if (when) I get an S52 I'll certainly change the tranny.
            • alpinweiB
              • 287
              yes i know i already read a lot of pages of that thread but i talked to someone about it and he didnt think that the tranmission would bolt up. glad to hear it does.
              [quote=hoveringuy;1091145] I used Doug's bracket, makes it plug and play.
              Does someone make a custom brace that you can buy or something?
              and another thing i have been told is that the pilot bearing on the M50 is larger than that on the M20. will that cause a problem?
