S52 from a 98 M roadster
  • John1180
    • Jan 2008
    • 267
    Is this a good candidate for an E30 swap? Can I use the gearbox that comes with it?
  • shiboujin
    • Feb 2006
    • 2791
    I believe that uses a ZF tranny. So youd need a 328 or 98 M3 (both manual) (u join style only) drive shafts or an E30 M3 drive shaft. You can use the stock x member and E21 mounts (I did). The rest IIRC is a regular swap.
    • hoveringuy
      • Dec 2005
      • 2754
      Very poor candidate.
      but I'll buy it from you...
      :grin:
      • etxxz
        • Feb 2006
        • 2085
        you can use its engine, harness/ecu/key/ews electronics...its gearbox, its driveshaft, its differential, its front suspension/spindle/brakes/5-lug, its rear suspension/trailing arms/brakes/ebrake/5-lug, its rims etc etc etc
        98% of my swap parts came from that engine...a/c compressor is also lighter than other s52 ;d
        just do it!
        No more e30s for me.
        88 black BMW OBDII 332is dedicated track [sold]
        88 BMW OBDII bronzit 332is [RIP 03/08]
        91 BMW 325i [sold]
        86 Corolla 'Ae86' HB 20v trd [sold]
        http://youtube.com/watch?v=pTj7Hn9v5Rs
        • btec116
          • Jun 2007
          • 131
          Z3 Front Spindles! Is this a worthwhile 5-lug option for the front end? Off topic I know, has this (specifically geometry differences) been discussed anywhere else? I'd love to do it but want to keep the front geometry. Also, there's someone trying to flog a full H&R coilover kit nearby that I've been too scared to get...
          • etxxz
            • Feb 2006
            • 2085
            same geometry...see the 5-lug subforum. btw your e30 has no 'spindles' per say, its integrated into the strut so read carefully...i'll give you an overview though. swap control arms, spindle, struts/springs (or c/o), calipers, rotors (they are huuge 315mm vs 260mm), sway links. done. get the damn car!!!!!!!!!!
            91 BMW 325i [sold]
