So I'm finally getting off my ass and making a build thread and hopefully a project blog soon, once I figure out what hosting service to use. The scope of this project is to build a DD with enough power for some fun. Nothing heavily modified, since I need to keep it legal and reliable. The victim is an '88 325is with 231,xxx miles on the current engine. Here's a shot of it:
Here's the build sheet, along with some notes:
Rebuilt '99 M3 s52 engine with:
-OBD1 intake + OBD1 sensors + e34 525i oil pan, dipstick and tube
-OBD1 harness
-3.5" 540i HFM
-24 LB injectors
-AA chip for all mods
Rebuilt '99 M3 ZF Tranny
UUC Aluminum flywheel w/e34 M5 clutch
e36 Drive shaft
YEAR? e28 535is 3.25 LSD
Stock e36 M3 exhaust for now
Porsche 944 brake booster
I'll compile a more detailed list when I get a chance.
Some engine pix:
Along with the new engine, I'll be installing all new suspension bushings, sway bar links and control arms. Using all stock rubber (I know, I know) for now. I like it comfortable for commuting. The current suspension is made up of H&R Sport springs and Bilstein Sport shocks.
I'm also changing the whole interior to black (stock color is tan) with a complete set of front and rear seats from an '88 M3. I've already replaced the carpet with an anthracite one, which I dyed really dark charcoal with SEM vinyl dye. The front seats have also been replaced. The rears are waiting a re-dye to be installed.
The last thing I'll do is paint the car-all the top surfaces are toast. The clear-coat started going last summer and is now pretty gone after only 1 year.
The car is staying 4-lug, and right now I'm thinking about eventually getting a BBK.
The engine is currently at the machine shop-I'll detail the disassembly process and machine work done in the next update.
-OBD1 harness
-3.5" 540i HFM
-24 LB injectors
e36 Drive shaft
Some engine pix:
