I thought this only plagues Mcoupe/roadsters....
  • PiercedE30
    • Apr 2005
    • 4220
    Stu: I actually pulled a E36 diff cover off of a random E36 diff in the warehouse at my work today. I checked to see if the bolt holes would even line up. Sure do. Gasket surface even lines up and is the same as the E30 188 diff. I'm going to make some brackets that I can weld to the frame rail and get rid of the stock one.
    My 2.9L Build!
    • E30godz
      • 1524
      Stu, that is serious business. You can blame it on me that one time you let me drive your car like 2 years ago.
      When you are coming to Raleigh?
      • SpecM
        • Oct 2005
        • 4531
        -Stu never lets me drive his car... :(
        1989 cirrisblau-metallic 325i
        • BeirBrennerE30
          • 2740
          uh ow....
          guess i need to be more careful until i do something about the diff. ive already lost a tooth on the ring gear. Thanks for bringing i to everyones attention stu and good luck with the fix
          e30sport.net
          '06 M3 Competition - 6-speed
          '97 Range Rover Vitesse
          • Mike
            • 932
            I'd claim shipping damage, if you can track down the car's history to some bullshit used car dealership. There's alot of money out there, you just gotta know where to look.
            Supatek -noun - your basic know it all
            • golde30
              • 11464
              Jon, make more of those brackets and sell them as e30 upgrades with the diff covers...i will buy one!
              IG: @Baye30
              • PiercedE30
                • Apr 2005
                • 4220
                hahaha
                Actually, I have made a little head way in the bracket area. Not much, but a little. I do have a diff cover with a male -4 AN coupler coming out of the overflow hole. I will be running that to a catch can underneath the battery box. Let me get the first set done and tested and I will definitely start making them.
                My 2.9L Build!
                • matt
                  • 3732
                  You know you can buy brackets and body panels from BMW... buying another of the M coupe diff mounts and installing it on the other side might work... if you can actually put the e36 diff bushing into that mount.
                  I would say fix it right the stock way and don't worry about it.
                  • PiercedE30
                    • Apr 2005
                    • 4220
                    But why use a single sided mount when the whole unit could use support on both sides?
                    This is actually something I have been thinking about for a while. I have seen way too many diff bolts (the ones on top of the subframe) back out without the use of some form of locktite. With the additional mounting point you would have far less of a chance of those bolts backing out. I sure if you could get a torque wrench up there, some how, you wouldn't have to worry about it, as much. But with the limited amount of space between the trunk floor and the bolts, you pretty much have to use a open end wrench to tighten them. I don't know about you, but I would be much less worried about it if there was an additional support.
                    My 2.9L Build!
                    • funcrew
                      • Jun 2007
                      • 1223
                      Originally posted by PiercedE30
                      If you want some reassurance, go ahead and throw an E36 diff cover on and put in new mounting tabs. Easy and doesn't allow the diff to rotate to one side easily.
                      Is there a write-up for that somewhere?
                      "If the sky were to fall tomorrow, the tall would die first."
                      -Dr. Paul Forrester
                      Do I LOOK like I need a psychological evaluation???
                      • PiercedE30
                        • Apr 2005
                        • 4220
                        I'll have one up for everybody in the next few weeks. When I get a chance.
                        It basically just bolts up. I mean it is a direct swap, you need the long bolts from the E36 diff (the side ones) cover, but that is it. I am going to look at where the tabs end up being positioned based on the stock tabs. I am thinking that I may be able to use the rear most stock mounting tab since it looks like the E36 tab will be right on the outside.
                        I'll make sure I take lots of pictures when I do it.
                        My 2.9L Build!
