which clutch...m50 w/ m20 flywheel
  • jakeb
    • 1909
    Which clutch should I run with a stock m50, 240 trans, and a m20 flywheel.
    stock m20 clutch and PP?
    or a HD PP and a 6 puck sprung from IE?
    thanks
    jake
    www.classicdaily.net
    1970 m42 swapped 2002
    1985 LS1/T56 Swapped e28 (557e)
    www.blunttech.com - For all your parts needs
    Follow me on Instagram for constant build updates @classicdaily
    https://www.facebook.com/ClassicDailyLLC
  • hoveringuy
    • Dec 2005
    • 2752
    I have M50 w/260 trans and have the stock clutch with a lightened flywheel. No slippage, no problems.
      • 37833
      I'm running a 6 puck E30 m3 clutch with my S50 and M20 flywheel. :)
      Grover Beach, California
      BimmerHeads.com
      • amonster
        • Jul 2008
        • 7
        I had my S50 rebuilt with new cams etc, and when it was time to set the Vanos, it couldn't be done by the book because you need to lock the crank via a pin in the flywheel that isn't there on the M20 setup. The weight and the cost are great things, but be aware of this one. I wouldn't do it again as I always think about if the timing was set correctly when I run the thing up high in the Rev's.
          • 37833
          Yes, it's good to have a stock flywheel available for this exact reason.
          BimmerHeads.com
          • PiercedE30
            • Apr 2005
            • 4220
            Don't use a Spec Clutch. The pressure plate WILL come apart on you. (first hand experience)
            My 2.9L Build!
            • jakeb
              • 1909
              I ordered a stock m20 clutch kit. $197.... I am into that
              • Rev Engineer
                • Jan 2006
                • 162
                I had the same experience with an s50 + spec e30 325i clutch/PP/flywheel. I'm not sure if the PP failed because of the additional power, or maybe the PP was defective to begin with.
                • Drew325is
                  • Oct 2004
                  • 520
                  Onthe M52 I'm running a Sachs "heavy duty" E30 325i clutch kit on a lightened E30 325i single mass flywheel. No complaints at this stage.
                  • jakeb
                    • 1909
                    you are talking spec e30...not the stock e30 part right?
                    jake
                    • PiercedE30
                      • Apr 2005
                      • 4220
                      jake
                      No. Spec Clutches. Look them up.
                      Rev: I actually had mine fail on a dyno. Right when the motor got to 7000 we heard a pop and a ticking. Turns out one of the drive straps and rivets let go out of the pressure plate. The rivet actually put a small hole in the transmission. I am still using the clutch disc though. I haven't heard anything about the disks being bad.
                      My 2.9L Build!
                      • golde30
                        • 11464
                        damn that sucks balls. i almost went with the SPEC setup on my s50. Sachs goodness i went OEM...hehe
                        IG: @Baye30
                        • Black_E30
                          • Apr 2008
                          • 32
                          Drew,
                          Got a link and/or sales details on that Sachs e30 325i "heavy duty" clutch kit?
                          I've been searching for a bit and it seems that companies are not advertising sport / heavy duty Sachs kits for e30 325i - unlike my recollection from the past.
                          Closest I found is Korman; they do lists individial "heavy duty" parts, but not as a kit and as usual do not have the prices on their web site. And sometimes their site is out of date anyway.
                          • evil_twin
                            • Nov 2007
                            • 2965
                            on my m52 motor with a ZF trans, I am using a F1 Racing (ebay brand) 6puck clutch, lightweight flywheel, and sach pressure plate. I love the way it feels, and my friend has it in his e36, and it hasn't given him any troubles yet.
                            Paypal: vdang5@gmail.com
                            Delta Auto Care
                            2875-C Towerview Road
                            Herndon, VA
                            703.435.1375
                            My Feedback Thread: Evil_Twin
                            • Bmjpv
                              • Mar 2007
                              • 561
                              clutchs
                              I installed the e3o M3 clutch kit w/alumium flywheel on my built up S52. It only had about 15k miles on when it started to slip, low speed and even at speed with WOT. I have about 20k + and it stopped slipping just like it started slipping ,don't know?? Anyone got any ideas on why ? Joe
