Rebuilding an M50 check list
  • Jean
    • 18228
    Other than a gasket set, water pump, oil pump and head bolts what other items are a MUST when tearing one down while it's on the engine stand?
    Thanks!
  • PiercedE30
    • Apr 2005
    • 4220
    Timing chain guide rails, timing chain tensioners, new chains, etc.
    My 2.9L Build!
    • e30serg
      • Dec 2006
      • 562
      Well, it really depends on how much you're going to tear it down.
      All gaskets
      Front and rear main seals
      water pump
      all belts
      timing chains and tensioners
      oil pump (<- u sure? it's $$$), you may be able to get the rotor only
      all hoses
      clean injectors + new o-rings and maybe pintle caps
      fan clutch (unless you're going electric)
      thermostat housing (w/metal one)
      Are you freshening up the head?
      new valve oil seals
      new tensioners?
      new valves if needed?
      check all lifters...
      Basically go through every section of the pelican auto parts site and figure out what are the "wear parts"
      • Mako18
        • Jul 2006
        • 688
        If your replacing all of that, it would be wise to do a refresh its deff worth every penny to know what condition your motor is in!! (not much if you can do some of the things below yourself)
        Replace the above mentioned along with:
        fresh hone
        piston rings
        wrist pin clips
        main/thrust bearings,
        main bolts
        Going slightly OT but the Machining that should be done:
        acid bath (important to be properly cleaned)
        checked block cracks..magnafluxed
        check bore specs
        check block/ cylinder head mating surfaces. resurface/plain if needed.
        bore/hone cylinders depending on clearances..
        align hone the main bearing bores (if needed)
        check all threads... repair/rethread or just clean!!
        crank inspection for cracks or worn journals....polish/grind or replace if needed
        rods spec'd and reconditioned
        pistons cleaned and checked, check ringlands extra close!
        The list is not in the correct order and will continue to $$$grow$$$ but I don't know how deep you want to dig into you wallet..by the sounds of it not even this far.
        For a ballapark ..all of this locally ran $900 assembled on the Supra's 7mgte (shortblock)..friend of a friend did the work..yah yah its not a 1j, or 2j..who cares...
        Did you leak down test the motor by chance?
        • Jean
          • 18228
          So the timing chain, guides, rails are a wear item huh?
          Just did a quick run down through real-oem for the most obvious things (hoses and belts can be done after).
          Timing case - http://www.realoem.com/bmw/showparts...57&hg=11&fg=10
          04 SHAFT SEAL 48X65X10 1 11142249532 $15.74
          05 GASKET ASBESTOS FREE 1 11141720638 $3.17 See SI 110691387
          06 GASKET ASBESTOS FREE 1 11141720639 $5.36 See SI 110691387
          Oil pan http://www.realoem.com/bmw/showparts...17&hg=11&fg=10
          03 GASKET RING 40X4 1 12611277129 $2.01
          08 GASKET STEEL 1 11131437237 $35.71
          Seal http://www.realoem.com/bmw/showparts...61&hg=11&fg=10
          09 SHAFT SEAL 90X110X12 1 11142249533 $46.59
          10 GASKET STEEL 1 11141432240 $2.64
          vanos gasket http://www.realoem.com/bmw/showparts...82&hg=11&fg=15
          06 GASKET ASBESTOS FREE 1 09/1992 11361740840 $4.85
          11 GASKET RING A14X20-CUSN 4 09/1992 32411093596 $0.20
          14 GASKET RING A14X18-AL 1 09/1992 07119963200 $0.22
          17 GASKET RING A12X15,5-AL 2 09/1992 07119963130 $0.10
          19 O-RING 18X2 1 09/1992 12141727220 $0.49
          valve cover http://www.realoem.com/bmw/showparts...83&hg=11&fg=15
          03 SET OF PROFILE GASKETS 1 09/1992 11120034107 $???
          valve train http://www.realoem.com/bmw/showparts...06&hg=11&fg=15
          need to review
          head http://www.realoem.com/bmw/showparts...07&hg=11&fg=15
          04 GASKET ASBESTOS FREE 1 11121738963 $2.46
          06 CYLINDER HEAD GASKET ASBESTOS-FREE 1,75MM 1 11121726617 $101.56
          06 CYLINDER HEAD GASKET ASBESTOS-FREE 2,05MM(+0,3) 1 11121726620 $101.56
          07 SET BOLT CYLINDER HEAD M10X95 1 11121721938 $38.78
          09 TORX BOLT M6X50 1 11121726397 $1.40
          10 TORX BOLT M6X70 1 11121720729 $1.40
          11 TORX BOLT M6X100 1 11121720731 $1.67
          what does this include exactly?
          12 GASKET SET CYLINDER HEAD ASBESTOS FREE 1 09/1992 11129064467 $332.57
          rod bearings http://www.realoem.com/bmw/showparts...19&hg=11&fg=20
          05 BEARING SHELL, BLUE 45,00MM(0) 6 11241284850 $14.62
          05 BEARING SHELL, BLUE 44,75MM(+0,25) 6 11241284852 $20.09
          05 BEARING SHELL, BLUE 44,50MM(+0,50) 6 11241284854 $10.94
          06 BEARING SHELL, RED 45,00MM(0) 6 11241284849 $14.62
          06 BEARING SHELL, RED 44,75MM(+0,25) 6 11241284851 $10.94
          06 BEARING SHELL, RED 44,50MM(+0,50) 6 11241284853 $10.94
          valve train http://www.realoem.com/bmw/showparts...85&hg=11&fg=25
          01 TIMING CHAIN 1 11311432176 $59.99
          05 GUIDE RAIL 1 11311726480 $17.52
          07 CHAIN TENSIONER 1 09/1994 11311703717 $61.38
          13 GASKET RING A26X31-AL 1 07119963418 $0.22
          14 SCREW PLUG WITH GASKET RING 1 11311722674 $4.18
          oil pump
          http://www.realoem.com/bmw/showparts...76&hg=11&fg=30
          17 SPROCKET 1 11411719935 $32.92
          18 HEX NUT M10X1-LH 1 11411735137 $0.21
          19 CHAIN 1 11411719936 $30.41 See SI 110592504
          http://www.realoem.com/bmw/showparts...88&hg=11&fg=30
          02 SET OIL-FILTER ELEMENT 1 09/1992 11421730389 $9.60
          08 GASKET 1 09/1992 11421719855 $5.19
          water pump/ t-stat stuff http://www.realoem.com/bmw/showparts...03&hg=11&fg=35
          02 O-RING 68X5 1 11511711484 $8.26
          06 O-RING 60X3,5 1 11531265084 $1.62
          08 PROFILE-GASKET 1 05/1992 11531740437 $1.62
          intake manifold http://www.realoem.com/bmw/showparts...24&hg=11&fg=40
          02 GASKET 6 11611717259 $10.38
          04 PROFILE-GASKET 1 11611716174 $9.26
          09 CONNECTOR 1 02/1992 11611738629 $3.28
          10 O-RING 24X3,5 1 11611730725 $2.85
          11 CONNECTOR 1 11611735800 $3.46
          12 O-RING 9,12X3,53 1 11611735859 $0.62
          14 WASHER-GASKET 1 11611735736 $0.60
          15 GASKET RING 1 11611735735 $0.61
          fuel stuff http://www.realoem.com/bmw/showparts...69&hg=13&fg=15
          intake stuff http://www.realoem.com/bmw/showparts...81&hg=13&fg=15
          03 RUBBER BOOT 1 13541738757 $21.32
          03 RUBBER BOOT ASC+T 1 09/1993 13541703694 $32.92 +core
          • Jean
            • 18228
            fresh hone
            piston rings
            wrist pin clips
            main bolts
            check bore specs
            See, I am hoping I wouldn't have to deal with pistons/rods/crank at all though. Engine is at 129k, it's a 95. Basically I am trying to figure out if this is all worth it if I am paying only $500 for the complete engine.... or if it makes more sense to pay more upfront and try to find one with lower miles..
            • SpecM
              • Oct 2005
              • 4531
              -Hard to get your $$$ back out of a rebuild, but them again you can have a zero-miles m50, something that you can't just find anywere!
              -What you seem to be describing is a "refresh", not a "rebuild", tho
              -And yea timing parts are wear items, they just wear long
              1989 cirrisblau-metallic 325i
              • e30serg
                • Dec 2006
                • 562
                Give me a couple days and I can tell you what's in the head gasket kit and the bottom end gasket kit. I have both in my garage right now. I just got the engine/head back from the shop and I'm getting ready to reassemble.
                • PiercedE30
                  • Apr 2005
                  • 4220
                  If you pull the head, PLEASE, PLEASE replace the oil check valve in the bottom of the head. It just unscrews with a flat head. It is what causes the valve tick that many M5x motors are plagued with on start up.
                  My 2.9L Build!
                  • Jean
                    • 18228
                    Sorry, I am still a n00b when it comes to engine rebuilds or refreshes.
                    Great, thanks! Please do and any info on exactly what you recommend a shop do and not do is appreciated.
                    • e30serg
                      • Dec 2006
                      • 562
                      Ditto. I'm sure to replace that little guy.
                      You should really do a leak down test though. If the head gasket is fine, leave it alone.
                      Btw, what plans do you have for this motor now? Have they changed since you started the thread?
                      • Jean
                        • 18228
                        Have not changed, it's for my 89 325i autox car. I have to check the rulebook to verify if I can under the rules increase it's displacement etc though.
                        • golde30
                          • 11464
                          the top end gasket kit includes everything except the front crank housing gaskets if i recall correctly. the oil pan gasket also doesnt come with that kit.
                          IG: @Baye30
                          • Jean
                            • 18228
                            is the head gasket included?
                            • e30serg
                              • Dec 2006
                              • 562
                              Yes, it does include the head gasket.
                              Ok, this is for a Victor Reinz Head Gasket Set
                              Valve cover gasket
                              Spark plug seals
                              Exhaust manifold gaskets
                              Vanos gasket
                              Valve oil seals (24)
                              Intake manifold gaskets
                              Throttle body gasket
                              Exhaust header to downpipe gasket
                              Seal washers for temp sensors, cps, vanos oil line, etc
                              Rear coolant flange gasket
                              Injector o-rings (12) <-that's what they look like anyways.
                              Some other washer-looking seals, not sure what they are for.
                              Thermostat housing gasket
