Rebuilding an M50 check list
  • golde30
    • 11464
    oh and it does NOT include all the rubber seals for each bolt on the valve cover.
    IG: @Baye30
    • e30serg
      • Dec 2006
      • 562
      Without opening up the bottom end kit, I can see:
      Oil pan gasket
      Oil filter housing gasket
      Front main crankshaft seal
      Rear main seal
      Timing cover gaskets
      Oil pump gasket?
      Sensor washers (cps, etc)
      Water pump
      Thermostat
      • e30serg
        • Dec 2006
        • 562
        Yeah, no seals for each bolt. I thought it did.
        In short, you're 99% there if you get both the head gasket and bottom end kits. It would allow you to take the engine down to the block and head, and put it back together using new seals and gaskets.
        If this is going to be a track-only car though, and the leakdown comes out good, you may want to save your cash and just throw it in after replacing the gaskets. You really don't want to mess with replacing them once the engine is in the car, especially the front and rear main.
        • Aatos
          • Mar 2008
          • 43
          Removing/installing head and especially cams requires quite a few pricey special tools.
          • PiercedE30
            • Apr 2005
            • 4220
            ^^^ No it doesn't. It can be done just fine with a flat edge on the back of the cams. The hard part is getting the Vanos unit put in place.
            Jean, if you increase the displacement then you either have to run in SM or EMod. I am running in SM.
            My 2.9L Build!
            • Aatos
              • Mar 2008
              • 43
              I haven't ever done that job, I've just read the TIS procedures.
              I went and read the pelican head article and counted three tools: deep torx socket for head bolts, tensioner tool and the cam holding tool, which is far more reasonable.
              • Jean
                • 18228
                SM is fine, I just need to confirm to make sure i'll be within the allowed specs
                • hoveringuy
                  • Dec 2005
                  • 2721
                  I also replaced the VANOS seal on mine. Glad I did it, the old one was brittle and shrunken.
                  There's also an O-ring on the back of the oil housing that I wish I had done.
                  • PiercedE30
                    • Apr 2005
                    • 4220
                    Just get a Dr.Vanos vanos replacement.
                    My 2.9L Build!
                    • Jean
                      • 18228
                      Have you guys found out if there is an oem oil pump from any specific model/year (m50/m52/s50/s52) that's cheaper than the rest? I've checked on a couple part numbers on realoem and they were over $300...$$$
                      11411740155 over 300
                      m52 11411740154 over 330
                      • 1mz
                        • Jan 2009
                        • 641
                        good thread - I'm about to put in an order for all new gaskets/seals this week
                        http://l0st0n3.mybrute.com
                        http://l0st-0n3.mybrute.com
                        Work in progress: 1991 318i m50 swap
                        Feedback thread :up:
                        I prefer having a female in the car at all times. They generally smell good, but you do have to put up with that hole in their face.
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          Do NOT use a victor reinz gasket. Elring only.
                          Past Car : E30 S50 6 Speed 5 Lug 3.73
                          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                          ___________________________________________
                          BNB Designs
                          Engine Swaps, Fabrication, Innovation, General Repair
                          Richmond CA
                          Julian 848-248-8029
                          • RedTRex
                            • Dec 2008
                            • 249
                            Why do you say that?
                            Leave now before I shed my human form and kill you
                            • alexbaby88
                              • 219
                              If you pull the head, PLEASE, PLEASE replace the oil check valve in the bottom of the head. It just unscrews with a flat head. It is what causes the valve tick that many M5x motors are plagued with on start up.
                              Are you referring to the "Non-return valve" part # 11121735180?
                              • TurboFox93
                                • 173
                                Whats the life expectancy of a non vanos m50? I am getting a 92 m50 for free and was wondering what essentials should be replaced. The motor as 121,xxx on it. Any links on whats needed and how to preform a leak down?
