Originally posted by PiercedE30
View Post
Rebuilding an M50 check list
Originally posted by TurboFox93 View PostWhats the life expectancy of a non vanos m50? I am getting a 92 m50 for free and was wondering what essentials should be replaced. The motor as 121,xxx on it. Any links on whats needed and how to preform a leak down?
If you have an m50b28 get the e36 bentley that covers the 328i/is for an engine refresh on that. Most of the things are same or similar but I'd go with what the M52 actual walk through says over e34 walk through. That said; the only difference in e34 bentley should be oil pan/sump install with exception of a few connector locations of wiring harness and the obvious manifold refresh which will include vacuum lines.
Someone correct me if I'm wrong.
EDIT: Sry I just realized I bumped a terrible old thread. I forgot I was searching an archived discussion.UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
stripped out e30 rally project - in progress
M50NV -> M50TU E34 swap underway
