Shricks = Failed emissions
  • dougsic
    • Jun 2006
    • 284
    Mo power is betta!
    The last time I took the roller emissions test with stock S50 but Dinan chipped, the car ran so clean it got a "Fast Pass".
    Recently installed TMS kit with Shricks, 3.5 MAF, injectors and chip.
    Took the test today and flunked emissions test big time.
    Catalytic converter has about 2k miles on it.
    Anyone able to get this setup to pass?
    Maybe mo power ain't always so better.
    I gave away my Dinan chip after I did the swap. Anybody have a stock chip for an s50 to sell if I have to swap everything back?
  • Jean
    • 18228
    what shricks do you have?
    • atomic
      • Jun 2007
      • 5691
      Originally posted by dougsic
      Mo power is betta!
      :eeek: I do not need to be hearing this...
      Here they will do just a tail pipe sniff test on mine, so hopefully I can pass that with a similar setup.
      :drink:
        • 34844
        why did it fail? lean? rich?
        can you bump up the idle speed a little? usually a cammed car would fail because of the overlap between the intake and exhaust - since the exhaust valve is open so late some of it actually gets in the intake stroke. there are lots of ways to get a cammed car to idle well and cleanly, but we kinda have to know what was wrong first. ;)
        • Aptyp
          • 6584
          i thought it could only fail if the mixture was rich?
          • peerless
            • 285
            If your too lean, you get a lean mis-fire that will raise HC's and CO, and Nox as well.
            You can pass HC and CO and still fail Nox.
            Many reasons for failing, with out numbers its hard to tell. There are so many variables, but aggressive cams certainly don't help.
            • BeirBrennerE30
              • 2740
              my car does NOT pass emissions in Mass. not even close and I have a very similar set up. But I dont run a cat or any kind of emissions equipment at all.
              e30sport.net
              '06 M3 Competition - 6-speed
              '97 Range Rover Vitesse
              • hugh jass
                • 2220
                don't the turner chips run really rich at low rpms? you should be able to find a stock chip or an ecu on ebay that you can put in temporarily that should help you pass.
                i've got a schrick cam and a dinan chip in my m5 and it passed smog in california very easily. the shop i got the chip from said to not even try it with the turner chip that came with the car because it might fail so badly that it would get labeled a gross polluter in the dmv system.
                ______________________
                ex-Chief Operating Officer
                Blunt Tech Industries
                West Coast and Pacific Rim
                • matt
                  • 3732
                  Is it a cheap aftermarket cat? How hot did you get it?
                  Post up your emissions sheet...
                  • e30polak
                    • 6136
                    Off topic, but how much stronger does the car pull now? Trying to decide between Schricks nd Sunbelts. (Oh wait just realized you have a heavy e36 vert)
                    Advantage to Schricks is that I can send my chip back into Turner and get the tune for like $150. However, I've concluded from hours on bimmerforums that Sunbelts put out significantly greater power throughout the curve.
                    Sorry for going off topic.
                    INSTAGRAM: @UNDR8D_EMPIRE
                    • Van Westervelt
                      • 9365
                      I passed with flying colors with the 24lb injectors, 3.5 intake and tms tune, less the cams. Now I have the cams, and no cats. :)
                      • surebimmer
                        • Jan 2004
                        • 978
                        Will you post your numbers?
                        • Van Westervelt
                          • 9365
                          Mine or Dougs?
                          • sumyungguy
                            • Feb 2007
                            • 1313
                            I think hes talking about the test results....
                            • Van Westervelt
                              • 9365
                              Yeah, I know.
