Electric fans
  • erik325i
    • Jan 2005
    • 3567
    Electric fans
    My car currently has an s50b32 with the Euro radiator and no fan.
    At the track, my car lasted all day without overheating. Temps stayed about 210* the whole time.
    Driving through the hills the other day I got stuck behind slow people and my car kept overheating and I had to pull over and let her cool down.
    I want to wire up a Spal fan to toggle switch. I heard though that pullers are much more effective than pushers, but I don't have much room between my radiator and motor.
    What size fans are you all using? I was thinking about getting one of the low-profile 9" Spal pullers. Sound like a good plan? Anyone using this size? Will it be enough?
    Thanks
    Erik
    • 37829
    I'm using a 16" Spal pusher, works very well. I also have a 318is radiator which a 16" fan barely fits on for anybody wondering. :)
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • 318isbmw
      • Nov 2005
      • 2841
      Yep, I'm runnin a 16" permacool pusher. Yes it is a tight fit, very tight...
      • evil_twin
        • Nov 2007
        • 2965
        16" ebay pusher. works a lot better than my puller i feel.
        Paypal: vdang5@gmail.com
        Delta Auto Care
        2875-C Towerview Road
        Herndon, VA
        703.435.1375
        My Feedback Thread: Evil_Twin
        • Mike B.
          • Jan 2006
          • 987
          I am running a 16" SPAL pusher on my S50B32 with a PWR radiator. No cooling issues at all.
          • bmw325csi
            • May 2007
            • 4045
            Im running a ThermoCool 16" pusher. Im scared to remove the engine fan though because its like 90+ deg out here.
            harry/harout
            • BeirBrennerE30
              • 2740
              12" spal pusher on 318is rad... no cooling issues at all
              any pick of that side exit exhaust??
              e30sport.net
              '06 M3 Competition - 6-speed
              '97 Range Rover Vitesse
              • gobuffs
                • Dec 2004
                • 513
                IIRC I have a 14" pusher from a local auto parts store (read: nothing special...was like $75) installed on my S50B32 with a Zionsville radiator with no issues....oil cooling OTOH is a bit more difficult to deal with.
                • surebimmer
                  • Jan 2004
                  • 978
                  Erik check out the fans from http://www.siliconeintakes.com/ they are like $25 for a 10 inch 1250 CFM fan. And only $30 for the 14inch 1800 CFM. I want to try it out bc the price is so cheap.
                  • 416stroker
                    • May 2008
                    • 2448
                    Im runnin 14IN 1400cfm pusher with no cooling problems at all and Ive still got my ac.
                    84 318I Delphin RIP
                    87 325IS delphin 24v Sold
                    89 325 Alpineweiss
                    • golde30
                      • 11464
                      im runnin the spal 12" 1350cfm pusher, wired to the A/C fan wiring, meaning i can turn it on with the a/c button. been stuck in traffic in 90deg weather, never went past the half way mark on the stock temp gauge.
                      IG: @Baye30
                      • etxxz
                        • Feb 2006
                        • 2085
                        ran 1300cfm 16" 2.05" thick puller fan in my previous car and was a little worried about overheating at track events, i would run the heater sometimes.
                        now, 3600cfm 16" pusher that barely fits on my somewhat tweaked rad support frame. needless to say my car will never overheat. be carefull when you look for it on ebay. verify the p# with the zirgo website. pz...^^yeah run it on the a/c circuit tis the cleanest way!
                        No more e30s for me.
                        88 black BMW OBDII 332is dedicated track [sold]
                        88 BMW OBDII bronzit 332is [RIP 03/08]
                        91 BMW 325i [sold]
                        86 Corolla 'Ae86' HB 20v trd [sold]
                        http://youtube.com/watch?v=pTj7Hn9v5Rs
                        • jakeb
                          • 1909
                          Do you need to pull the AC condensor for the 3600cfm 16" to fit?
                          Or will it fit in place of the AC fan with the AC condensor still in place?
                          www.classicdaily.net
                          1970 m42 swapped 2002
                          1985 LS1/T56 Swapped e28 (557e)
                          www.blunttech.com - For all your parts needs
                          Follow me on Instagram for constant build updates @classicdaily
                          https://www.facebook.com/ClassicDailyLLC
                          • erik325i
                            • Jan 2005
                            • 3567
                            It looks like all you guys are running pushers. Maybe I'll just get a pusher as it will be a lot easier to fit. I'll take some measurements and see if fitting a puller is even possible in my car.
                            I don't have any detailed shots, but here is a picture someone took at the last meet. I also still need to attach the stainless heatshield around the tips on the sideskirt.
                            What oil cooler setup do you have?
                            Any issues fitting the puller in there? I don't have a heater anymore, so that's not an option.
                            Erik
                            • gobuffs
                              • Dec 2004
                              • 513
                              I had a Mocal cooler up in front of the radiator (sharing the front of the radiator with my fan). I5t was suggested I relocate it out from in the front of the radiator. I bought a Setrab cooler that is about 6 inches square and put it behind the passenger headlight (removed lights). I am thinking of putting another one below it under that shelf over there. Will know more after hitting Road Atlanta and Watkins later this month...but temps will be less than they normally are in Texas.
