S52 Stroker using S38 components???
  • e30polak
    • 6136
    Is it possible? that would be sick to do a 3.6/3.8 s52!!! Anyone with info please post up. BTW I haven't found anything with the Search function.
    INSTAGRAM: @UNDR8D_EMPIRE
  • e304me
    • Feb 2006
    • 1374
    not possible
    • e30polak
      • 6136
      Any other stroker options?
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        I think you can do an m30 stroker with an S38 crank......but not S52.
        • mattdk318i
          • Jun 2006
          • 3953
          im pretty sure this is correct. A S52 stroker just sounds mean. I think some of the only options will be aftermarket.
          • matt
            • 3731
            There are people out there who have offset ground cranks to attempt this. PTG did stroker S54 for a while also, I think. I would imagine they had the budget to have a new crank made.
            I wouldn't touch an offset ground crank with a 10 foot pole. 3.2 is plenty for plenty of power, and if you want more (especially in a street car) go for boost, not displacement.
            • 2002maniac
              • 4260
              especially if it will see over 6000 RPM
              • FredK
                • 14759
                It's ok. The M50 head flow sucks over 6000 rpm anyway.
                :mrgreen:
                • Stu
                  • 4083
                  :mrgreen:
                  With factory port-work, you're right. : )
                  • StreuB1
                    • Sep 2007
                    • 113
                    M50 head casting is the same as the S50/S52 as far as ports and combustion chambers. Assuming you meant head as a complete piece aka with cams where as the cams are inferior. :)
                    I like to build things with metal n stuff
                    • windnsea00
                      • 158
                      What is your opinion (or Dad's) on VAC's Stage I and II heads? I want to Sunbelt my S52 down the line and am looking into my options...
                      Past: 1991 330is; 1995 318ti; 1993 325is; 1997 318ti; 1989 332is; 1999 Z3 M Coupe
