Vanos Speciality Tools
  • madjurgen
    • May 2005
    • 1203
    I was just about to buy this:
    http://cgi.ebay.com/ebaymotors/ws/eB...m=170208051782
    So are you saying this is the wrong tensioner? For which motors?
    As time went on, the factory developed the car each year, making it faster, more comfortable, and capable of handling at higher speeds.
    You don’t want this. You want the trickiest, most dangerous, oldest model you can find. Only then can you prove to the world that you’re a man.
    • Mako18
      • Jul 2006
      • 688
      Well the part no. is different from mine but it looks the same as the one I have. I would ask them just to be sure. Don't forget about the sprocket tool and air fiitting they are just as important!!
      • madjurgen
        • May 2005
        • 1203
        Thanks. Following Pelican's fairly thorough instructions, they never use either of those tools.
        • FredK
          • 14763
          There are two chain tensioners. The one you posted, as pictured, fits directly into the head. The other one fits into the older two-piece timing chain tensioner so you must have the cup that screws into the head in order to use it properly.
          EDIT: I just looked at the auction and noticed that the part numbers are all over the place. I removed the PNs until I can clear up which tensioner is which.
          • Mako18
            • Jul 2006
            • 688
            Hmm weird because I have "101 performance projects for your bmw 3 series 1982-2000" from pelican and its stressed to use them. I would want to be sure everything is as close to perfect as it can be, its a job that should only be done once!! but to each his own..
            • MatRacer
              • 562
              Bringing back an old one
              according to the bentley, you only need the vanos sprocket rotating tool (spanner tool) is for 3/95 and later cars...
              I Didn't anythnig about the vanos air adator...?
              E30 now S52
              2008 Suburban LTZ (Family and TT hauler)
              325xiT (Sold)
              • gregslow318i
                • Sep 2007
                • 1918
                its a pta if you dont have it but it can be done w/out it
                looking for a e30m50 swap harness adapter pm me $150 shipped
                email nitroman12@gmail.com
                • e30s52
                  • Oct 2007
                  • 5235
                  You can rent them off ebay for 25 a week. I think thats what I paid.
                  www.gutenparts.com
                  • MatRacer
                    • 562
                    Them meaning all the required tools? (IE cam locking, flywheel locking, etc...)
                    E30 now S52
                    325xiT (Sold)
                    • e30s52
                      • Oct 2007
                      • 5235
                      It came with everything besides the chain tensioner and TDC pin but don't quote me on that. It has been awhile since I have done the swap. If you find it on ebay for rent ask them what is included.
                      www.gutenparts.com
                      • isolatos
                        • Dec 2009
                        • 172
                        My head is cracked. I have a guy that has a complete head (cams, vanos, etc) that I can get for $350. If my thinking is correct I shouldnt need any special tools to just swap the head-correct? Only if I wanted to take the head in to get cleaned and checked for cracks/resurfacing. Thanks-I have just started to research this..
                        • jrdeamicis
                          • Nov 2008
                          • 956
                          You will have to remove the timing chain which requires taking the vanos off. So yes you need the tools.
                          You can get it VERY close without the tools. But it won't be perfect.
                          Past Car : E30 S50 6 Speed 5 Lug 3.73
                          Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                          ___________________________________________
                          BNB Designs
                          Engine Swaps, Fabrication, Innovation, General Repair
                          Richmond CA
                          Julian 848-248-8029
                          • matt
                            • 3732
                            Definitely have the new head cleaned and checked out. Cheapest $80 you will ever spend if it's cracked.
                            • isolatos
                              • Dec 2009
                              • 172
                              Right on, thanks guys. I am nervous about dealing with this vanos system for some reason. Does anyone rent the tools out?
                              • LivingLegend06
                                • Dec 2006
                                • 1604
                                Did you even read the first post?
