[HOW TO] e46m3 6-speed your e30
We are half way through our g420 6speed swap and may have a trans crossmember to offer once we are finished, and the e36 m3 auto shaft is just barely long enough to fit, to get more spline engagement we may end up making a spacer for the guiboShawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
bimmerbuddiesllc@gmail.comComment
You need the clutch because the splines on the 6spd trans is different regardless of the engine selection flywheel you may be able to mix and match idk but clutch can't changeShawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
Bimmerbuddies LLC
717-388-1256
Just a quick update for anyone doing this swap and gathering parts. I've purchased a custom brace from Tyler at ArcAsylum that I'm very pleased with. Also if you follow most post about the slave cylinders for the e36 325is, the E36 M3, and the E46 M3 having the same rod lenth they are wrong. The one you definitely need is the E36 325is slave. This particular slave is just over 3/16 of an inch shorter than the E36 M3 slave. Using the E36 M3 slave will cause the clutch not fully disengage and clutch slipping will occure. Ask me how I know this.Comment
Does this only apply to the E46 M3 six speed? I have a 330 ZHP ZF transmission. It makes sense I would want to use the slave cylinder designed for that transmission when I install it in my S52 E30. Is this logic wrong? I was planning on running a stock E46 330 flywheel and 135i clutch as I have heard this is a good combo. Does clutch/pressure plate choice factor in to which slave setup is best?
run a e36/46 g250 or zf320 slave; it works just fine. Different bores but it allows you to tune to own liking.
330i flywheel will be LIGHTEST dual mass @ 20# but only accept self adjust pressure plate ( SAC)
Only the friction disc must match the trans splines.
You could also run aftermarket if desired.
For a street car there are many options. If driven with precision a m20 stock fly+clutch can handle a s52b32 in race situationsLast edited by Wanganstyle; 06-28-2015, 11:21 AM.OBD1 M54/M52TU swap as a M50b25
With any zf or getrag 6 speed you can:
330i flywheel will be LIGHTEST duam mass @ 20# but only accept self adjust pressure plate ( SAC)
I personally used an unsprung clutch and non-SAC pressure plate with an OEM dual mass flywheel on my old ZHP when I turbocharged and needed a stronger clutch. It was the Sachs Race Engineering setup. Very nice feel and the pedal was a bit stiffer but not unbearable. I would do this again in a heartbeat except the clutch and PP alone cost over $1K, not to mention the new OEM FW at $500. I would like to be able to run an OEM E46 330 FW with a non-SAC PP again. Can I get there using the 135i clutch plate on the OEM DM FW or would I need to run the OEM 135i PP as well?
Does anyone know if the 135i clutch plate has the 22 spline mount?Comment
You cannot bolt a 135 flywheel to a non n54/n55 engine. ring gear offset is also totally wrong.
You can bolt a m54b30 330i zhp 6 speed flywheel to any m54/m52/s54/s52
The 135i/335i oem clutch set (pressure plate+friction disc) will work with oem BMW m54b30 flywheel.
Oem BMW pressure plates from e39++newer are self adjustingOBD1 M54/M52TU swap as a M50b25
135i only came with 22 spline invouluted type
One last question: I have a lead on a 135i manual transmission from a 2010 N54 powered car with only 19K miles on it. You had previously stated that this transmission would bolt up to the S52. Does the input shaft have the correct configuration and length to be able to use the ZHP flywheel with the pilot bearing installed in the flywheel and the 135i clutch/PP combo? Would I be better off sticking with the ZHP trans I have already with 102K miles?
How about the mount to the chassis? Same steps to mount it as the ZHP?Comment
Bmw has the answers to your questions; it's really only just variations on a product line theme.
So by using the ZHP flywheel and 135i clutch and pressure plate combo I will get a stronger clutch but not be able to avoind the SAC feature? Are there really any MAJOR drawbacks to the SAC when the CDV is deleted? Can I expect a vague clutch engagement running this combo?
SAC and CDV are 2 completely different cans of worms; you should probably spend some time reading on the E39 boards in regards to the SAC and its function.
if you have driven a properly maintained E39m5 or E46m3 with original clutch you have driven a SAC clutch; its not like they fail often; more like the owners destroy the car and everything fails.
Do you have a turbocharged engine or NA engine? This would make a big ass difference for gearing choice of the box; turbo gearboxes from BMW have ratios to suit turbo engines...Last edited by Wanganstyle; 06-29-2015, 06:11 AM.OBD1 M54/M52TU swap as a M50b25
EDIT: Just realized the 135i clutch has a 26 spline input shaft center. The ZHP trans has a 22 spline. Thought you said the 135i clutch was a good option? Did I miss something?Last edited by jph; 08-07-2015, 09:44 PM.Comment
